Noise On Hard Acceleration
Old 20 Jul 2014, 02:35 pm
Default Noise On Hard Acceleration
So a few weeks ago I drove my car over a pretty dramatic pot hole in the road and it started to develop this. After taking it to the mechanic he found that the bushings on the lower control arms were pushed out and it was the metal to metal that was creating the noise.
I have since replaced the control arms, but the noise still lurks. It only occurs when I am accelerating, or when there is a lot of torque. Like going up a steep hill or driving initially from a stop.
Old 20 Jul 2014, 02:47 pm
Default Re: Noise On Hard Acceleration
Welcome to the forum.
Whinning, clicking, scraping, popping? Can you describe the noise it's making?
Old 20 Jul 2014, 03:09 pm
Thank you. And it sounds like a metal on metal vibration. I believe that maybe part of the exhaust was bent and vibrates on something on acceleration.
Old 20 Jul 2014, 03:16 pm
If it is, the only way to tell is to get under the car and shake different parts of the exhaust and see is any part rubs, knocks against the frame or around the rear axle where the exhaust pipe makes a loop over it and back towards the rear. Could be up the front part where the flex pipe comes off the header and back to the CAT.
Old 20 Jul 2014, 03:23 pm
I am changing the oil today anyway so it will be the perfect time to check that. I'll look around and see what i find.
Old 20 Jul 2014, 05:00 pm
This is what I found. The bolt on the AC compressor will press up against the metal when the engine twists under load. A quick fix to me is to take a metal punch and try and to bend the metal, but that is rather "not the right way." What do you recommend.
Old 20 Jul 2014, 05:19 pm
LionPT's Avatar
Check your lower motor mount, if it's bad replacing it should fix your problem.
Old 20 Jul 2014, 05:37 pm
Old 20 Jul 2014, 05:38 pm
Is that just the aluminum strut?
Old 20 Jul 2014, 05:43 pm
How to replace lower motor mount
Strange Siren Noise upon acceleration Cali777 General Turbo Discussions 6 11 Jun 2012 06:04 pm
My Car Makes Hissing noise when driving.. no noise from reverse or netural kasasoze Turbo Performance 3 04 Dec 2011 09:07 pm
Noise upon acceleration ncbeachchick Tech & Performance Forum 5 04 Dec 2009 07:22 am
whining noise when acceleration??? ruzz1 Tech & Performance Forum 9 09 Nov 2007 07:46 pm
acceleration and decceleration popping noise Art Rigby Tech & Performance Forum 1 06 Oct 2003 02:30 pm
