Failed high-beam switch melted connector
Old 21 Jul 2014, 08:06 am
Default Failed high-beam switch melted connector
My gf has an '01 Cruiser and since it was purchased the high-beams never worked. This was several years ago and she's always lived in cities until now, so she never cared about her high beams.
Troubleshooting it this past weekend I found the highbeam switch to be bad, according to manual pin 17 should have continuity with 18 and 19, which it does not. However, I also noticed the 20 pin molex connector itself was damaged. I am guessing a weak connection generated enough heat to likely damage the switch but also melted, warped and discolored the connector. This connector needs to be replaced but I certaintly don't want to go ripping out the entire harness to do so.
Does anyone know where I can get a replacement connector? I don't have an issue splicing in all 19 wires.
Old 21 Jul 2014, 08:16 am
Default Re: Failed high-beam switch melted connector
There's a member named Brian who tearing apart a cruiser and he's willing to cut things out as he told someone who's looking the the OBDII connector so he could get your part also. Here's his profile so you can contact him. He's new to the forum so I can't say if he's a good seller or not. Buyer beware.
http://www.ptcruiserlinks.com/forum/...brianr112.html
Old 21 Jul 2014, 08:21 am
Thanks CREWZIN, I'll message him. Much appreciated!
Old 21 Jul 2014, 08:36 am
LionPT's Avatar
$65 at RockAuto: AIRTEX / WELLS 1P1610
Old 21 Jul 2014, 08:53 am
Rockauto, I didn't know they carried connectors at all. I did a general google search and came up empty handed. I assumed it was too much of an odd connector for an aftermarket company to make.
I may have to consider this if I can't get one from another PT. Thanks Lion7718!
Blowing high-beam fuses otfiddler General PT Cruiser Discussions 5 29 Apr 2014 07:23 pm
2004 High Beam's not working?? jrunner Interior Accessories Forum 3 03 Oct 2013 11:22 am
High Beam on 2001 LE Jassy General PT Cruiser Discussions 1 06 Jul 2013 12:32 pm
Melted multifunction switch cgleibrand General PT Cruiser Discussions 0 11 Oct 2011 07:06 pm
High beam fuse keeps blowing 92awd4g63 General PT Cruiser Discussions 5 23 Nov 2010 03:18 pm
