Does this idicate a bad ignition switch?
Like Tree2Likes
  • 2 Post By sanatanadharma
Old 21 Jul 2014, 09:51 am
Default Does this idicate a bad ignition switch?
Hello All!
Ok, back to the drawing board. A few weeks ago I had a problem with 05 PT(manual trans) randomly starting, boiled it down to being able to start her by jiggling the relay box under hood, where wiring harness, that worked for maybe 10 to 20 starts then I would have to do again. New thing is PT stopped while I was going 60 MPH down the rd, but this time I could not get her to start no matter what I did with the relay box. Had to have her towed home. So my question is now, I'm wondering if could be the ignition switch? I have done all the recomadations I have read on here, such as trying to start with direct wire to starter and all I get is engine trying to start but doesn't turn over, checked relays they are indicating no problems. Thanks for any input
Old 21 Jul 2014, 02:10 pm
Default Re: Does this idicate a bad ignition switch?
Check PDC fuse #13 (20 amp) and the auto-shut-down relay.
Also check fuse #11 (10amp) in the dash fuse block.
Old 21 Jul 2014, 04:50 pm
Not sure what that means.
Trying to start usually means starter spins the engine, but no ignition.
"doesn't turn over" means starter doesn't turn engine.
MAY be switch, but check fuses and ASD relay first.
Ignition switch lt4supr Tech & Performance Forum 10 21 May 2016 06:28 pm
Ignition switch?!?! Lolo376 Tech & Performance Forum 19 23 May 2014 11:20 am
Ignition Switch BMAC1206 General PT Cruiser Discussions 10 22 May 2012 03:27 pm
Ignition Switch??? Don162 Tech & Performance Forum 2 19 Aug 2009 11:03 am
Possible Ignition Switch? bkarr Tech & Performance Forum 4 20 Jul 2008 06:25 pm
