PT Surging? missing?
Old 22 Jul 2014, 07:11 pm
Default PT Surging? missing?
01 PT new wires,plugs gapped at 40,,,new cam sensor,,new crank sensor...tectron gas treatment..
idles nice and smooth runs good when u get down in it hard. but up to about 3grand its surging? weard like its missing? dont wanna pull good..But if you nail it it will go and pulls great,,
it Sat for a few months before I bought it..I replaced the tranny and clutch and the above...NO CODES??...no smoke..
any ideas or experience with this?.. no codes with a hand held scanner and no codes on the key dance?..
Old 22 Jul 2014, 09:04 pm
boonie2's Avatar
Default Re: PT Surging? missing?
[QUOTE=drumrooster;531918]01 PT new wires,plugs gapped at 40,,,new cam sensor,,new crank sensor...tecktron gas treatment..
idles nice and smooth runs good when u get down in it hard but up to about 3grand its surging? weard like its missing? dont wanna pull good..gut if you nail it it will go and pulls great,,
it ast for a few months and I bought it and replaced the tranny and clutch and the above...NO CODES??...no smoke..
any ideas or experience with this?..[/QUIf you could translate this part "dont wanna pull good..gut" "it ast for a few months and I bought it and replaced the tranny and clutch and the above...NO CODES??...no smoke.."
2004 Pt Cruiser 2.4 L {non turbo} 113K miles , Electric Blue pearl {PICTURES in my Profile Album}
Full Synthetic Oil 10w30 K&N Filter
Full Synthetic Trans Fluid / filter Change :bolt-away
Old 22 Jul 2014, 10:18 pm
How did you determine "NO CODES"? I trust it was with a Diagnostic Scan tool at your OBDII diagnostic port. And that you also checked the I/M?
If not and you used , say the key dance, than lets try this again, what codes did you get?
Old 22 Jul 2014, 10:41 pm
Red face Re: PT Surging? missing?
yes used a hand held scanner and tryed the key dance ..no codes..I just went and got more gas and added some sea foam? tryin that for now,,
sorry for the miss spellings lol...
its surges when your pullin up to around 3g between shifts..and seems like its week around 55 in 5 gear? ...
one more thing the P/O put one of those damm fart can mufflers on it..lol
actually sounds ok but I still hate it..I"m wondering if thats messin with it? cause of back pressure?? or something??
Nitro whats the I/M???
Old 22 Jul 2014, 10:48 pm
Surging is part of the emission monitoring system within the PCM, You should be seeing a DTC? If not than you have a sensor or multiple sensors that are at their sensible limit which would not activate a DTC. IMO you may consider doing a spark plug reading at load with ignition shut off. That is unless you have a way to do a DATA log the operating systems during the event of surging?
You back pressure is not an issue even if you removed the resonator with what you describe your mods are to your PT. Now if you said a mandrel 3 inch full exhaust than maybe we could talk about loss of bottom end but still not surging?
May I recommend to try to resist the attempts in the future of key dance DTC access for the troubles you are having.
Old 22 Jul 2014, 10:57 pm
I always check both key and my scanner for codes..how would I check the plug reading?...would a dealer scann maybe show more? I "ve NEVER had any luck with the dealer..they always say it checked out fine and I usually figure it our on here or myself..
but I"ve not had this PT there..$90 to run there scann
Old 22 Jul 2014, 11:29 pm
gosch.. for another 30 bucks you can get a great diagnostic scan tool at Harbor freight!
Old 23 Jul 2014, 07:37 am
I already have one. and it not showing anything. maybe it will if I keep driving it.?
Old 24 Jul 2014, 04:03 am
chris15's Avatar
My guess is the ignition coil. Do you ever see a check engine light at all? An active misfire will be caught by the PCM and won't store a code, it'll just flash the CEL at you and then disappear.
2003 GT (6262, the works)
2001 PT MTX-Swapped/Turbo
Old 24 Jul 2014, 06:15 am
Thanks Chris..thats exactly what my next thought was...but no check engine light dont come on. At all..drove it to work today 50miles runs great .only does it between gears shifting up
.and it does seem lk a misfire to me..if it dont smooth out i guess ill buy a coil..thanks..will keep u posted..
Surging at 3700 rpm Caustic Tech & Performance Forum 3 05 Aug 2013 09:05 pm
surging problem briand805 Tech & Performance Forum 0 29 Nov 2011 05:51 pm
Surging at Idle Scarlet2003 Tech & Performance Forum 9 18 May 2011 08:39 pm
Surging Problems WikiFiend64 Tech & Performance Forum 4 16 May 2008 09:07 pm
04 Cruiser surging Ursa General PT Cruiser Discussions 6 09 Oct 2007 07:32 am
