start then die
Old 22 Jul 2014, 09:48 pm
Default start then die
Help! I have a 06 pt cruser non turbo. I had a problem with the transmission going into limp mode and after reading some posts I decided to install some aditional ground straps to fix that problem. I also decided to take off the 4 plugs connecting the ecm and clean with contact cleaner. After putting 4 connectors back on I found out that now car will start and then almost Immediately stops running. I can also hear what sound like the fuel pump running. I checked fuses in the engine compartment. Any ideas ?
Old 23 Jul 2014, 05:29 am
Default Re: start then die
Did you disconnect the negative battery terminal before messing with your computer?
Old 23 Jul 2014, 05:46 am
I did not disconnect the ground on battery first. Don't know what i was thinking. It seams everthing works dash light ect but maybe i scrapped the ecm ?
Old 23 Jul 2014, 07:28 am
No, probably not but do it now. disconnect the negative battery cable. Step on the brake pedal to get rid of any residual charge, wait five minutes and hook it back up. Start the car (if might run ruff for a couple minutes but hopefully it will keep running.
Sounds like something with the security (engine only runs for about 3 seconds if it doesn't recognize the key) and maybe disconnecting the battery will reset that.
Old 23 Jul 2014, 08:19 pm
So I disconnected the ground lead as you advised. Brake on and it cleared the starting stoping problem. I drove down the road then brought home. And then went back out to start agian and the same problem start then die. I did notice the little round icon on dash was on and off. I also noticed that if i keep the key in start position it will run a little longer but still dies.is there anyway to bypass this problem just temporary to determine that's the issue. Thanks agian for any help.
Old 23 Jul 2014, 08:29 pm
The little round icon might be the security light. Do you have another key you can try?
Old 23 Jul 2014, 08:58 pm
I tried my other key already. And also tried locking the doors and unlocking the doors with both keys then got in and started then died. Sorry to be such a pain. I bought this car for my son cause I alway thought they were cool. But this little guy has thrown me for a loop. I would just take to dealership but i went by there to get transmission codes when the original problem of going into limp mode set in and the dealer wanted between 600 and 1200 $ to get to the root of the limp mode problem. So I don'ttrust those guys much thanks agian for any help
Old 23 Jul 2014, 09:11 pm
The ONLY thing I can think of now is the ignition switch. Since you said something about leaving it in the start position. A few owners have reported problem of the car stopping and not starting and it turned out to be a faulty ignition switch. Might want to do a search on Google or on this forum for ignition switch problems.
cruserdad1976 likes this.
Old 23 Jul 2014, 09:51 pm
Ok i will just replace switch and will post back the results.
Thanks for the help
Old 23 Jul 2014, 11:03 pm
cruserdad1976's Avatar
what about the remote key start??
PT Won't Start CREWZIN Tech & Performance Forum 13 01 Feb 2014 12:09 pm
Car won't start duck3233 Tech & Performance Forum 3 20 Oct 2013 03:32 pm
no start 05stockpt Tech & Performance Forum 0 17 Feb 2013 10:07 am
car didn't start in the cold, got jumped then was a bubbling sound and won't start Saqqara Tech & Performance Forum 1 15 Dec 2009 06:35 am
PT Won't start... morrises General PT Cruiser Discussions 5 16 Jun 2008 09:57 am
