signal light doesn't work when breaks applied
  • 1 Post By SinglerStudios
Old 23 Jul 2014, 07:13 pm
Default signal light doesn't work when breaks applied
Hey Guys heres an odd one for you. My passenger side signal works fine. The drivers side signal works fine too until the break is applied then they go out, take my foot off the break signal works. I was thinking there must be a short in the rear socket? I figured I'd check here first before I replace the socket. Thanks guys!
Old 23 Jul 2014, 07:59 pm
LionPT's Avatar
Default Re: signal light doesn't work when breaks applied
Check the bulbs also, front & back...it sounds like they might be single filament bulbs.
Old 24 Jul 2014, 10:14 am
I'm gonna swap the bulbs now, they are the same ones that have worked fine the past 6 months but who knows if one filament failed and is hitting the other.
Old 24 Jul 2014, 11:21 am
JDB JDB is offline
Both failing at the same time...now THAT would be weird! ;~)
Just on a lark, look up under the dash and make SURE that when you mash the brake pedal that a wiring harness hasn't come loose and fallen down onto the pedal. It could be something as simple as the brake pedal arm or plunger contacting a wiring loom and causing a momentary disconnect in the wiring for the turn signal.
Just a thought?
By the way, I had a Ranger that when a brake light bulb would go out, the cruise control would stop working properly. And if both brake lights went out...the cruise quit working all together. LOL
Go figure? I HATE computers. ;~)
Old 24 Jul 2014, 12:02 pm
I'll have to check under the pedal! I just changed the bulbs and both stopped working completely in the rear. After a few minutes the drivers side rear worked again but still goes out when breaks pushed and rear passenger is completely dead now.
Old 24 Jul 2014, 06:01 pm
I got them working now even when the brake is pressed. It's all back to normal. I noticed that the previous owner had wired in a harness for a set of trailer lights, it was done pretty poorly so I removed it and rewired the originall harness back together and it's all good to go. I'm going to order a pair of new bulb sockets to be safe though mine are kinda crispy. Thanks for the help guys.
Old 24 Jul 2014, 07:01 pm
boonie2's Avatar
Same thing happened with mine , corrosion inside the socket so i just replaced both , Dealer price was $14.95 each junk yard price $ 1.00 for both
2004 Pt Cruiser 2.4 L {non turbo} 113K miles , Electric Blue pearl {PICTURES in my Profile Album}
Full Synthetic Oil 10w30 K&N Filter
Full Synthetic Trans Fluid / filter Change :bolt-away
Timing belt done, now AC doesn't work. falconut Tech & Performance Forum 22 04 Apr 2014 07:32 pm
Fog Lamp doesn't work.... sommerregen General PT Cruiser Discussions 2 04 Nov 2013 01:09 pm
A/C Doesn't Work when Idle - Do I need a Fan? mriggins Tech & Performance Forum 10 29 May 2013 02:24 am
air conditioner doesn't work... problem with switch kcerica Tech & Performance Forum 4 27 Jul 2011 07:22 am
fan doesn't work but doesn't overheat 4SPEED General Turbo Discussions 3 07 Nov 2009 10:20 am
