Engine noises
  • 1 Post By quicksilverdon
Old 24 Jul 2014, 08:03 pm
Default Engine noises
My 02 started to act funny on me, you can hear some ratteling when its hitting 20 to 40 mph, changed the knock sensor, no luck, injector cleaner, no luck, been using premium gas and the knocking goes away for a couple of days, I know that in carburated cars the rattling was caused by the engine not being timed correctly, took the car to auto zone, they hooked up the code reader and a issue came up with the ABS, and they also said the there was a major communication between the computer and the sensors, anyone experienced this problem before? Do I need to replace my computer? ny info. is appreciated
Old 24 Jul 2014, 08:11 pm
Default Re: Engine noises
Do you know what the ABS sounds like? It hammers... and you might be confusing it with pinging.
If it is pinging, your knock sensor could be bad.
implala66 likes this.
Old 24 Jul 2014, 09:09 pm
No problems with the ABS and already replaced the knock sensor
Front end noises Chromenut Wheels, Tires, Suspension 1 24 Jun 2014 06:51 am
Noises From Back of Car thomasm516 General PT Cruiser Discussions 6 09 May 2014 11:20 am
rear end noises freekshow Tech & Performance Forum 3 07 Jul 2013 10:03 am
question about brake noises 4SPEED Tech & Performance Forum 6 25 Jun 2008 05:41 pm
Turbo noises quicksilverdon General PT Cruiser Discussions 5 05 Apr 2005 02:08 pm
