I recently bought a 2001 pt cruiser, manual transmission, from my neighbor. It came with a k & air filter. It had 83000 miles. I have replaced the radiator thermostat water pump and timing belt. Car runs good and smooth but is only getting 15 mog in town. I have had tire pressure checked. Is this normal? Anything I can do? Thanks for your input!
![]() Quote:
Check air Filter Change plugs- USE CHAMPION Change O2 sensor USE CHRYSLER (or your wasting your money) on the exhaust manifold How does the car idle? Idle speed? No matter what you change expect to only get 19-20 mpg for local driving mabe a little more if your driving an area that all flat. I have a Sebring the gets me about 20 mpg during a 23 mile commute, same engine.
Addicted to Mopar You can tell how old I am.. 65 Dodge Coronet 6 cyl 2dr Post 66 Ply Satellite with 273 engine swap to 69 340 4spd 70 340 4spd Dart Swinger "Those were the days my friend" 73 Charger SE Had a few Vetts on the way 69, 85 Several Neons some flips 01 Sebring flip Cruiser's 01, 220K Gone to a new home Cruiser 03 133K Gone to a new home Cruiser 06 110K Project Gone to new Home Cruiser 05 Ltd 120,809 bought with broken belt Oct2015 May 16 Resurrected to once again roam the streets. 20 Miles South Of Pittsburgh |
I get 20mpg no matter what. 15 might just be road conditions.
2004 PT Cruiser Base ~ Light Almond Pearl Metallic Clearcoat
2 JL Audio 10's ~ Jensen 900.1 42mm LED Dome Light |
in my 5-speed NA PT i get 22mpg suburban driving, shifting at 4-5k pretty much flooring it light to light. i have the rear seats taken out, the front tires at 40psi, rear tires at 38psi, and a cone K&N in place of the airbox.
i agree the plugs are worth a shot, although i had the worst plugs in the history of the forum and when i changed them out, i saw NO benefit in MPG or performance, so don't expect a miracle. is the new thermostat rated at the stock temperature, is your temp needle just a hair under the 1/2 way mark? |
Thread Tools | |
Display Modes | |
pt troubles | 05ptgirl | Tech & Performance Forum | 4 | 21 Jul 2012 12:23 pm |
IAC troubles | rob342 | General PT Cruiser Discussions | 1 | 16 Jun 2012 01:55 pm |
06 troubles | Jocko | Tech & Performance Forum | 4 | 26 Apr 2012 02:02 pm |
Car Troubles | PTCMIAH62 | General PT Cruiser Discussions | 9 | 07 Sep 2010 11:00 am |
New guy... MBC troubles | SRT | Turbo Performance | 3 | 02 Apr 2010 10:40 am |
