PT Cruiser leaking
Old 25 Jul 2014, 04:12 pm
Default PT Cruiser leaking
Hey guys, it's me again. This is probably nothing but I did a few errands today: got gas, went to store, etc and every time I parked my PT it was leaking water from the front right side of the engine. Not massive amounts but there was definitely a drop , the first time it was easily a cup or more, the rest of the time it was some, not as much but some. It's water, clear water and I wasn't running my AC cuz it is 60 degrees, the car is not overheating but the fan is coming on, I can hear it every time I turn off the car.... Any clues? Thanks.
Old 25 Jul 2014, 04:21 pm
Default Re: PT Cruiser leaking
Nothing to worry about. That's condensation from the A/C system. Even if you have the controls on defrost, the compressor is activated and you'll have the condensation on the ground. It should be coming from a rubber tube pointed directly at the ground (if you care to get under there and take a look).
Old 25 Jul 2014, 04:23 pm
Even if I didn't use the AC cuz it is cold today??
Old 25 Jul 2014, 04:26 pm
Clear water?
You do have anti-freeze/coolant 50/50 mix with water in your coolig sytem, don't you? That should be yellow, or green, depending on brand you use.
A/C condesation should be only clear fluid in car, but you said you weren't using A/C.
Is right side of car to you driver's side or passenger side? R and L are determined from drivers seat.
Only other clear fluid would be battery acid.
Old 25 Jul 2014, 04:28 pm
Crewzin must have the answer. i did not know that compresor came on except with a/c swith.
Old 25 Jul 2014, 04:30 pm
Uh, I hope it's not battery acid cuz I tasted it !!! It didn't taste like anything and it is definitely not colored , looks like water , not oily nothing. I hope it's just AC condensation but again everything was off, no defroster, nothing on.
Oh and thank you both for the quick replies and knowledge!
Old 25 Jul 2014, 04:39 pm
cruserdad1976's Avatar
well battery acid will taster really sour??? I guess thats the best answer and im sure you would ahve know that really quick
Old 25 Jul 2014, 05:35 pm
Ok, it keeps doing it, water, a big drop every few seconds, are you guys sure this is ok ? Cuz it is freaking me out! I stopped for about an hour and it still does it. I tasted it again, I know I shouldn't have! Tastes like water, looks and feels like water and I even used white tissue, no color. It's just a lot of water to me, is it going to stop? If / When should I start getting concerned? .... thanks.
Old 25 Jul 2014, 05:38 pm
Are you sure your not using the compressor? Even if you have it towards the heat setting, if the control is pointed towards the defrost, the compressor might come on. I know in a hot day here, when I pull into the garage, there's a large puddle, I'm talking a foot and a half across right near the passenger front tire in just a minute or two.
Old 25 Jul 2014, 05:46 pm
Not using anything, I mean all of the little knobs are to the center /off position. When I use the AC I have seen water but it stops after a while and this one just keeps on going and it's almost 4pm....
pt cruiser leaking power steering fluid when sitting idle win717 Tech & Performance Forum 0 28 Jun 2014 06:05 pm
BOV already leaking! WPTF General Turbo Discussions 3 10 Mar 2014 03:55 pm
04 Cruiser, Overheating & Leaking? Please Help ChevySS Tech & Performance Forum 3 20 Feb 2014 06:46 am
Oil leaking Subwaymike General PT Cruiser Discussions 4 16 Feb 2014 10:52 pm
Leaking red oil jsparr Tech & Performance Forum 8 04 May 2011 09:55 pm
