Engine stutters when lightly accelerating
Old 28 Jul 2014, 12:51 pm
Default Engine stutters when lightly accelerating
Hi-
I have a 2002 PT Cruiser Limited with an automatic transmission and about 110,000 miles.
The car has developed a stutter or hesitation when I accelerate at about 2000 rpm and am traveling about 45-60 mph. If I stomp on the gas pedal it downshifts fine- It only seems to happen when I am lightly accelerating.
I get no fault codes and the check engine light has not come on.
Any suggestions would be greatly appreciated!
omahapt
Old 28 Jul 2014, 01:27 pm
Default Re: Engine stutters when lightly accelerating
WELCOME TO THE FORUM
First line of business would be the usual easy to-dos....
spark plugs
spark plug wires
If you do not want to foot the inexpensive cost of fresh parts which seems to be needed than you can check the resistance in each of the wires and pull the plug and examine them.
Old 28 Jul 2014, 02:07 pm
110,000 miles have you had you timing belt changed today? It's over due.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 28 Jul 2014, 02:47 pm
I will replace the plugs and wires and see if that helps....thanks!!
Old 28 Jul 2014, 03:13 pm
When doing the tune-up Be careful not to damage surrounding parts like sensors and the connectors.
Good Luck!
Hope to hear back from you the results!
2006 PT Cruiser bucking when accelerating + no check engine codes mattamusprime General PT Cruiser Discussions 4 26 Mar 2012 08:59 pm
engine light accelerating the pt beeps everytime? PTCHANDLER General PT Cruiser Discussions 5 08 Dec 2010 01:21 pm
Engine Light + Bucking When Accelerating kalyhan Tech & Performance Forum 9 06 May 2010 10:06 am
My PT stutters! bluemonster Tech & Performance Forum 2 09 Aug 2009 01:30 pm
engine stalls or stutters while in idle or stopped with a/c on, but not with a/c off traumadude376 Tech & Performance Forum 6 12 Aug 2008 12:15 am
