Overheating when AC is turned on
Old 30 Jul 2014, 06:09 pm
Default Overheating when AC is turned on
Hello guys!
I have a 2006 PT Cruiser touring edition 2.4 and noticed that my car starts to over heat when I have the AC on. The AC actually stops working well when I'm in idle, however once I am on the freeway, the car is able to cool down, and the AC kicks in just fine. I popped the hood and let my car idle with the AC turned on, and sure enough my Radiator fan was not coming on. So I ordered a brand new fan from Rockauto.com. When I called around looking to get the best pricing, a mechanic told me he wouldn't put a customer ordered part because you have to properly diagnose the vehicle first. I thought that if the fan isn't coming on, then it must be broken. The mechanic said, it could be a number of reason that the fan isn't coming on, for example:
1) Relay
2) Module
3) Temperature sending unit
4) Motor
Can anyone give me insight or verify if this mechanic is correct? If so, is it better to just let the mechanic diagnose the issue or is it probably just a bad fan? Thank you in advance for all your help!
Respectfully,
Allen T. Schroeder
Old 30 Jul 2014, 07:57 pm
Default Re: Overheating when AC is turned on
Find a new mechanic. The Cruiser is well known for premature fan breakdown. In the mechanic's defense, he IS right, to a degree. But for him to not install your fan (which you can do with very little difficulty), is asinine.
2016 Kia Soul Plus Black
Old 30 Jul 2014, 08:10 pm
Allen, soyomb is correct. Find someone else. Even my dealer took my parts for the timing belt and installed them. They just won't give a warranty if the parts don't work. Ask around for someone to do the job for you.
Overheating when engine turned off ! scottc123fish Tech & Performance Forum 1 25 Sep 2012 01:35 pm
Popping noise when A/C turned on wmc7 General PT Cruiser Discussions 2 20 Jul 2011 04:48 pm
Electrical issueS... (fog lights always turned on... radio display turned off.. etc) benoit_bertrand Sound and Security Forum 5 09 May 2011 03:09 pm
Cooling Fan No Go when AC is Turned ON betterred Tech & Performance Forum 14 20 Feb 2011 11:05 pm
power on with key turned off and out of car oklahomabob Tech & Performance Forum 3 04 Dec 2010 07:17 pm
