Rough idle, spark knock / pinging
  • 1 Post By rob342
Old 31 Jul 2014, 12:31 pm
Cool Rough idle, spark knock / pinging
2001 2.4L with Whipple Supercharger. Engine is idling very rough, sounds like it's running on 3 cyl at the exhaust. No trouble codes. When driving it is now noticeably pinging (spark knock) under medium to hard acceleration below 3500 rpm. Seems to have less power than normal. Is this a symptom of an intake leak? Or a hole in a piston? Or? I haven't checked anything yet, just thought I'd ask some questions before I start on it.
Old 31 Jul 2014, 12:55 pm
Default Re: Rough idle, spark knock / pinging
Connect a hand vacuum gauge to the intake manifold either tee into the PCV or the brake hose. Than start your engine and report what the gauge is doing.
If you do not have one than now is the time to invest in one! They are at most all better auto parts chain stores for around 15-30 bucks.
Old 31 Jul 2014, 03:01 pm
Do you mean the type with the vacuum squeeze handle and gauge? Also, I have a gauge inside the car that shows vacuum and boost, will that tell you anything?
Old 31 Jul 2014, 03:11 pm
Animated Engine Vacuum Diagnostics
NitroPT likes this.
Old 31 Jul 2014, 03:35 pm
sucking threw hose hahaha!
Originally Posted by rob342 View Post
The gauge in the car may be to small to see good small movements unless it is digital. See my gauge and what Rob posted.
Rough Idle-Replacing the IAC Idle Air Controller engineerrock Tech & Performance Forum 9 07 Jun 2014 07:24 pm
'07 PT - Rough Idle, rough acceleration, and shuts off if it idles for too long La_Bruja Tech & Performance Forum 3 09 Aug 2013 07:50 am
spark knock sound under any acceleration Steve Clark Tech & Performance Forum 20 19 May 2011 07:01 pm
Rough Idle, Rough @60, check engine light NEW Dystroy Tech & Performance Forum 8 12 Jan 2009 09:07 pm
new guy/Spark Knock Thrusst Turbo Performance 7 05 Mar 2006 11:26 am
