TIMING BELT NIGHTMARE! NEED ADVICE
Like Tree5Likes
Old 01 Aug 2014, 09:54 pm
Default TIMING BELT NIGHTMARE! NEED ADVICE
Hello all, Ive been a frequent visitor to this site the last 2 weeks. My 2002 pt cruiser died on the way to work 2 weeks ago. After going up a hill and making a left turn about 15 to 20 mph it began to sputter as if it was running out of gas, shut off and would not restart. Had it towed to a friends mechanic and of course it was the timing belt. I was given a estimate and the job was supposed to take 2 days. Well 2 turned into a week and it was a mess when I went to pick it up. The engine was shaking violently, coolant was leaking out, something under the hood was rattling very loudly. I was mortified! I test drove it and as long as I was moving she ran OK a little sluggish. The idle was a different story. I refused to take it in that state. One of the mechanics says to Me " this is the best were going to get it" just leave it here and we will check it again. Fast forward to now. Frustrated i refused to pay the whole repair price I picked my car up the next day it ran better but the engine still shakes. My gas gauge isnt working, fans dont come on ac not working and the idle is awful. The mechanic changed his number and no one seems to know were he is. Took it to Conrad's this morning and picked it up after work. THE ENGINE HAS LOW COMPRESSION THIS IS WHY IT IDLES BAD.???? Could be the timing was not set properly or the engine valves were damaged when the belt broke. Only way to find out is to pull the heads and this is about a $400 job on top of the previous belt job not to mention if its the valve. I'm not sure what to do at this point I don't have what if? money to waste. Should I have the heads pulled or get rid of it. I've only owned this pt cruiser 5 months she has 129,000. How likely is it that I have internal engine damage?
Old 01 Aug 2014, 10:17 pm
Default Re: TIMING BELT NIGHTMARE! NEED ADVICE
If timing belt is off one tooth you will have low compression. Thats your problem. All your othe conditions are the fault of the first guy. Mechanic not! Get the belt in time and you can see what all he left in disrepair.
rob342 likes this.
Old 01 Aug 2014, 10:19 pm
boonie2's Avatar
The so called Machanic you used did NOT set the timing right sounds like at the very least its one or two teeth off ...
edited - busted beat me to it .. word to the wise ? NEVER use a Machanic you know nothing about.. have a Machanic you TRUST reset the timing RIGHT , I wouldnt drive it too much until you do or you WILL have internal damage
2004 Pt Cruiser 2.4 L {non turbo} 113K miles , Electric Blue pearl {PICTURES in my Profile Album}
Full Synthetic Oil 10w30 K&N Filter
Full Synthetic Trans Fluid / filter Change :bolt-away
Old 01 Aug 2014, 10:22 pm
LionPT's Avatar
Have the timing checked, most likely that is your problem. As for your fuel gauge & A/C, that's a different problem.
Old 01 Aug 2014, 10:27 pm
cruserdad1976's Avatar
Ok FIRST OFF the chances iof bent vavves is SLIM verry SLIM espically going the speed yu said you were going
HE PROBLEM IS SIMPLE IT IS OUT OF TIME
1 tooth wil make it idel rough
the low compression is odd but if its not in time its going to be wrong
The best of the Best will some times get the timin worong it isd a hard and pai in the tush Job many have done it wih no problem most ay they learned new cuss words
They unhooked or brke the seal on the AC while messing with the T/B they most likely did nto get the other things pluged back in to where they actualy go
Thsi is what gives some good mechanics a really bad name
The $400 is cheap if thats all they charge you---did you replace the water pump and tensioners at the same time??? id check the theromastat and housing they may ave been rough adn the PT does not do rough well
My guess is Timming is off everyhing you say its doing is timing related more or less
Just my 2 cents other will add to
Old 01 Aug 2014, 10:28 pm
wow you guys maust typer relaly fast or im half asleep
Old 01 Aug 2014, 10:34 pm
KA9VQF's Avatar
Probably using a phone or tablet to post with. Just my guess cuz I really suck with those devices.
Old 01 Aug 2014, 10:35 pm
Yep DROID
Old 02 Aug 2014, 06:07 am
Unhappy Re: TIMING BELT NIGHTMARE! NEED ADVICE
Thanks for everyone's reply. Cruiserdad1976 I really pulled the short end of the stick on this one. My regular mechanic moved to Florida two months ago and I was referred to this other guy by my boyfriends family. Im not familiar with car repairs. I've blew threw $1200 this past 2 weeks between the first guy and Conrad's testing and I can't afford to waste any more time or money. Is it a good idea to go ahead and have the heads pulled ? Conrad's gave me a estimate of about $400 to pull the heads and see what's going on. If its the timing that's off I'm looking at another 6 or 7 hundred bucks to fix. Am I better off just getting rid of it? The car was great before this but I need reliable transportation for work.
Old 02 Aug 2014, 06:20 am
Yes @cruiserdad1976 I actually purchased the kit that came with the water pump
Tags
engine shaking, rough idle, timing belt replacement
Time for the Timing Belt Nightmare boonie2 General PT Cruiser Discussions 8 25 Apr 2014 07:39 pm
Wow!..talk about a timing belt nightmare. PTJunkie General PT Cruiser Discussions 18 25 Mar 2013 12:27 am
Timing belt shield, belt replacement. jdwalk04 Tech & Performance Forum 13 14 May 2012 10:01 am
