07 PT touring - 107K - timing belt
Like Tree3Likes
Old 02 Aug 2014, 12:45 pm
Default 07 PT touring - 107K - timing belt
Newbe to the forum here - Just got this really nice 07 PT, and going through what need to be fixed. Typical stuff broke (Probably why it was sold) Bad rad fan, bad upper and lower engine mounts. those are next weekend. The forum has been such a great help getting those both sorted out.
My question is: Is there any way I can tell if the timing belt has already been replaced? Any access or inspection hole I could use to check the belt condition?
Any help would be appreciated...
Old 02 Aug 2014, 01:10 pm
cruserdad1976's Avatar
Default Re: 07 PT touring - 107K - timing belt
not really all belts ware differently some have 100,000 and look good some a ratted up IF you could check the water pump and tensioners that would be a better way to tell but im not sure you have access to them plus if the mounts were not changed I dought the Timing belt was either
Busted_PT and boonie2 like this.
Old 02 Aug 2014, 03:28 pm
boonie2's Avatar
No way to be certain , just changed mine with a Kit , everything "looked" ok but its good to KNOW where you stand
2004 Pt Cruiser 2.4 L {non turbo} 113K miles , Electric Blue pearl {PICTURES in my Profile Album}
Full Synthetic Oil 10w30 K&N Filter
Full Synthetic Trans Fluid / filter Change :bolt-away
Old 02 Aug 2014, 08:15 pm
If it was a dealer serviced vehicle It would show in their service record and with a little thought that you need and estimate the dealer might show you that it was done previously. Just a thought,
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 03 Aug 2014, 10:15 am
It makes sense that if the motor mounts are shot, the timing belt was probably not changed. I bought this car at an auction and unfortunately no service records were in the car. Also it's an out of state car.
The good thing is that it has been taken care of very well, interior, exterior are in excellent condition, the engine bay is dusty but overall clean. fluids and wiring all in good shape. Engine strong, AC cold, shifts great.
I've watched several Youtube Timing belt replacement videos, and read the threads on the forum. Really good info, but that project looks like a real PITA.
I think I will knock out the fan and motor mount replacement, that's kinda cheesecake stuff. The timing belt no so much.
For those who have had their timing belt replaced what was the price for the belt, tensioner, water pump replacement?
I have several dealerships (will use only if I have to) and some auto service shops near me. Just trying to determine a reasonable price to expect. Thanks again.
Old 03 Aug 2014, 03:10 pm
I'd take a chance and take the vin to the dealer and tell them that you bought the car and there were no records with it, ask if its on any recall list or TSB list. and could you tell me if their dealer serviced the timing belt?
When I took my Neon to the dealer to get a used ECM they told me it was originaly titled in Sweeden. They reprogrammed the ECU and new key.
73 Charger SE
01 Sebring flip
Old 03 Aug 2014, 05:22 pm
its between $750-#1200 for a timing belt job depends on where and who parts are usally under $200
Old 03 Aug 2014, 05:55 pm
boonie2's Avatar
Timing belt , Water pump , Tentioner , Idler , Mounts were all good so I saved that $50 , Recharged the AC.
Total labor $551 / Parts $105 / $656 not Bad for Florida
Old 03 Aug 2014, 09:18 pm
rckstein's Avatar
You can pay for a CARFAX report by providing your VIN#. I recently got one for my PT and the report contains a lot of service history. Could give you some valuable info on what has been done.
LionPT likes this.
Old 03 Aug 2014, 09:27 pm
it only counts if it were taken to a place that reports to carfax
timing belt ? jimhoysa Tech & Performance Forum 3 02 Apr 2014 07:28 am
Timing belt shield, belt replacement. jdwalk04 Tech & Performance Forum 13 14 May 2012 10:01 am
Belt change help - Not timing belt skfloyd Tech & Performance Forum 2 23 Apr 2010 11:23 am
