Horn honks just ... because!
  • 1 Post By RacerX125
Old 02 Aug 2014, 03:33 pm
mdfrodolives's Avatar
Default Horn honks just ... because!
Hello again, everyone.
I got the overheating sorted out; now there's a new item.
I was unloading groceries from my car, and with a handful of bags--while inside the house--I heard a horn, honking.
It turned out to be mine.
The liftgate was still open so I closed it to see if the horn would stop honking. Nope.
Then I put the key into the ignition and started the car, then turned it off and withdrew the key. No reset of any kind. The horn kept on going--short, regular blasts. There was also a click, click, click under the dash that clicked in time with the horn blasts.
So I go into the garage to get a wrench to undo my battery, lifted up the air-cleaner housing, started to undo the negative lead on the battery--but then the honking just stopped on its own.
I tried the Search function and got nothing like my issue.
Anyone know what's going on? I'd appreciate if anyone could tell me.
Thanks,
Tim
Old 02 Aug 2014, 03:36 pm
boonie2's Avatar
Default Re: Horn honks just ... because!
Same thing happened with My Van once , took off the connector , cleaned it up alittle , and all was fine , could even be a short somewhere , bare wire maybe
2004 Pt Cruiser 2.4 L {non turbo} 113K miles , Electric Blue pearl {PICTURES in my Profile Album}
Full Synthetic Oil 10w30 K&N Filter
Full Synthetic Trans Fluid / filter Change :bolt-away
Old 02 Aug 2014, 04:01 pm
You took off "the connector" at the horn, itself? I'll check into that.
But this honk, honk, honk was more like when you hit the panic button on your key fob. Very regular. And there was a matching click, click, click somewhere in the dash, at the same time.
Also, it just stopped on its own--as if the entire sequence was on a timer.
I don't know how long the alarm goes on, but I would assume it stops after a good five minutes, or so.
Tim
Old 02 Aug 2014, 05:41 pm
that click click click sound might be coming from your RKE Module which could explain the honking, maybe you pressed the panic button and didn't notice?
On my 03' if I press the panic button the horn starts beeping and I can hear a click click click sound everytime the horn beeped. That's my theory which might be wrong
Old 02 Aug 2014, 06:16 pm
Racer, I think you got it right.
My wife says I must have bent over while unloading groceries in the kitchen and pressed the panic button, unknowingly. Since I've never done it before, I had no idea that you were supposed to press the panic button once again to make it stop.
The honking shuts off automatically, she says, to keep the battery from running low.
It might be a good thing if I went through my owner's manual again ... after all these years.
Thanks for the replies, folks,
Tim
Horn honks too long DecoCruiser Tech & Performance Forum 7 12 Nov 2012 09:28 pm
2002 PT Cruiser horn honks on ignition mikenguy General PT Cruiser Discussions 0 17 Oct 2010 06:25 pm
HELP - horn honks all the time PatJ General PT Cruiser Discussions 4 25 Jan 2009 09:10 am
New Horn Sandy-GRR8PT General PT Cruiser Discussions 11 06 Apr 2006 08:40 am
the horn turbomangt Sound and Security Forum 16 28 Feb 2003 08:09 pm
