Major Tyre wear plus mounting rubber split
  • 1 Post By JoeX
Old 03 Aug 2014, 11:49 am
Unhappy Major Tyre wear plus mounting rubber split
Hello all,
My first post here on the forum. Used it many a time fixing my other half's 2003 PT mind you!
I am hoping some helpful soul will be able to steer me in the right direction for an issue I have found.
I initial went under the car to look at the HO2S as she's getting a MIL light (P0038), however that was put on the back-burner when I spotted some major wear to the OSF tyre:
So...I delved a little further and spotted this:
A bigger overview pic:
So....my question is this....could that split rubber have this major impact on the inner tyre or is it simply the Tracking is out? Just to note, I did get the garage to sort out the track rod end a few months ago while I was away on business.
Any thoughts? Any advice would be appreciated
Old 03 Aug 2014, 03:52 pm
Default Re: Major Tyre wear plus mounting rubber split
Looks like your in need of a new ball joint and a bad ball joint affects camber adjustments and it will wear the inner or outer edges of the tires.
Old 03 Aug 2014, 04:34 pm
Thanks for the heads up, much appreciated.
Will look at replacing the whole control arm then!
Old 03 Aug 2014, 06:18 pm
and I thought winter road salt was bad in Pennsylvania..
Spray the Lower Conrtol Arms retainin bolts and let them soak
Good luck
cruserdad1976 likes this.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
P0455 Major Evap Leak Major issue h_wingman Tech & Performance Forum 16 27 May 2018 12:03 pm
Recommended tyre pressure siddharta1979 General PT Cruiser Discussions 30 09 May 2014 08:45 am
Changing front seats - Tyre sizes - Engine size StephenLPhillips General PT Cruiser Discussions 10 26 May 2013 10:47 am
Tyre size question! Botok Wheels, Tires, Suspension 5 07 Jul 2012 11:09 pm
