Help. Pt won't start
Like Tree2Likes
Old 03 Aug 2014, 01:50 pm
Default Help. Pt won't start
Have a 06 pt cruiser with 113000 miles. My girlfriend left the car running for a minute in the parking lot and it just died and would not start. It would turn over but not start. Went and bought a new battery but was doing the same thing. Ended up checking the codes and received a p0340 and a p0562. I am trying to figure out if the 562 is causing the other code. I went out to work on it this morning and I can't even get it to turn over. Please help!!!! I know the 340 is the cam shaft sensor but can't figure out the power problem.
Old 03 Aug 2014, 02:56 pm
Default Re: Help. Pt won't start
Did you miss the opportunity to change the timing belt before the cogs (teeth) stripped of or the belt broke? I believe if the belt breaks there is little chance of valve damage but if enough cogs strip off the belt the crank can still drive one cam out of timing enough to possibly bend valves, It happen to one I purchased.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 03 Aug 2014, 03:08 pm
LionPT's Avatar
Replace the Cam Sensor, the low voltage code might go away after the car is actually running.
boonie2 likes this.
Old 03 Aug 2014, 06:00 pm
boonie2's Avatar
Change out the Belt / Water pump and tentioner , idler, repl. the cam sensor
2004 Pt Cruiser 2.4 L {non turbo} 113K miles , Electric Blue pearl {PICTURES in my Profile Album}
Full Synthetic Oil 10w30 K&N Filter
Full Synthetic Trans Fluid / filter Change :bolt-away
Old 03 Aug 2014, 06:31 pm
Thanks for the help guys. Just cleaned all the battery terminals so the low power codes r gone. Still getting the p340 and took the sensor off and the magnet is not turning so I am assuming it is the belt. Didn't realize how much I will have to take off just to check the belt. Any tips would be appreciated.
Old 03 Aug 2014, 06:56 pm
boonie2's Avatar
you may be able to pry the cover apart at the top just to see IF the belt has snapped , slip a flathead screwdriver between the seams and twist it apart, no way to check the condition of it without going all the way.. learned from some very knowledgable people here that a belt that LOOKS good doesnt mean a thing
Old 03 Aug 2014, 07:12 pm
I tried that but all I could see was the top and it didn't look loose. I asked her if it made a noise before the car shut off but she said no which I find odd if it broke.
Old 03 Aug 2014, 07:20 pm
xwing777's Avatar
There is 3-4, small (i think 8mm) bolts holding top timing cover on and you can remove it and see if belt is broke or turns when cranking
boonie2 likes this.
Old 03 Aug 2014, 07:37 pm
Can only see the top of the belt but it feels tight. No play at all. I am very confused right now.
Old 03 Aug 2014, 07:46 pm
I'll repeat: If the cogs on the inside of the belt strip off, the belt will still have tension but be out of time. If the missing cogs are over the front cam gear (like Mine were) the valves "COULD" be touching and the starter cannot turn the motor over. I would hope I'm wrong for your sake.
73 Charger SE
01 Sebring flip
Pt just won't start mattie1972 Tech & Performance Forum 6 19 Aug 2013 09:58 pm
where do I start to fix brvalleygirl30 Tech & Performance Forum 1 10 Feb 2012 06:41 pm
car didn't start in the cold, got jumped then was a bubbling sound and won't start Saqqara Tech & Performance Forum 1 15 Dec 2009 06:35 am
What a way to start the day!! Knotsobright1 General PT Cruiser Discussions 7 06 Oct 2009 12:00 am
Ran out of gas and now won't start Gracie512 Tech & Performance Forum 28 09 Jul 2009 10:15 pm
