04 manual touring edition -@ higher rpms cutting out
Old 04 Aug 2014, 06:53 pm
Default 04 manual touring edition -@ higher rpms cutting out
Hello, new guy here with a 2004 manual PT cruiser touring edition
About a year ago, at RPMs at and above 2400 the engine would sometimes sputter and something in the drive train would shutter, I could toggle the ignition off/on a few times and problem went away for a while, then it just quit one day, would not start and after sitting for an hour, it finally fired up. Took it to a friend, he replaced a Speed sensor and MAP sensor and the problem appeared to be fine. Fast forward to today, same symptoms started occurring when on the way to work, toggled the ignition off/on and seemed ok, then on way home from work, problem occurred and engine shut down and for hours would not re start, starter is spinning and if I pump the pedal a bit, it tried to catch, but would not start. Had it towed home and now here to search for any possible help.
Old 04 Aug 2014, 08:42 pm
Default Re: 04 manual touring edition -@ higher rpms cutting out
Made a few phone calls and started poking around and found my timing belt is broken. Could a bad or going bad timing belt cause the stuttering at 2400+ rpms?
Or do I have another issues that caused the timing belt to break?
Old 04 Aug 2014, 11:16 pm
I see you didn't mention how many miles on it. Nothing causes the timing belt to break except age and mileage. When you repair it, tensioner and water pump should be replaced as well.
2016 Kia Soul Plus Black
Old 04 Aug 2014, 11:56 pm
Yeah, forgot to add that, just over 100K and I have owned it for 40K.
I did hear to do water pump, tensioner and a gasket or two during the repair, but also heard of a good chance for a bent valve. Not sure how to check for the valve issue before getting deep into the timing belt replacement. Book time on the timing belt is almost 8.0 hours and I will have some help, but a bent valve may send me to a repair shop instead of my garage.
Old 05 Aug 2014, 02:46 am
Install the replacement new parts and put the engine in time. No need to put covers or other belts on, The bent valve check is do a compression check. IF you get one cylinder that reads low you know there the problem lies.
NO, the belt could not cause studdering, if it was running out of time it would run rough at idle and less power over all.
100,000 miles, same clutch? Could be slipping. Ever change spark plugs, wires?
Now your choice is instead of just new timing components, the engine and tranny needs parted to change the clutch.
You should also do the belt for the alternator and the idler tensioner, Power steering-ac BELT.
Ever changed your lower control arms or bushings, engine mounts, check your tyrods?
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
HELP PLEASE 2001 PT Limited Edition Manual Broken CruiserBrokensad Tech & Performance Forum 0 19 May 2013 02:41 pm
05 Touring Edition. Fan whitec1001 Tech & Performance Forum 8 13 Apr 2013 07:12 pm
higher price = higher quality? edb General PT Cruiser Discussions 13 26 Oct 2011 04:05 pm
2005 PT Cruiser Touring Edition Manual Low Milage Selling Cheap hushpuppy Classifieds: For Sale/Trade 7 23 Sep 2011 06:54 pm
Engine surging at 4000 RPMs along with shaking at 2000 RPMs... brian5060 Tech & Performance Forum 3 24 Jul 2010 07:42 pm
