I was replacing my front brake pads and rotors and decided to inspect the passenger side motor mount and notices that one of the sections of rubber has a crack all the way through it. There is a lot of vibration at idle so I think this might be the cause.
Should I just replace it with an mount that I can get shipped free on Amazon or keep the one I have and add one of those mount inserts you can buy? |
I'll see if the installation procedure in the Haynes repair manual when I get home.
Amazon mounts from "Anchor" free shipping bet. $ 12 - $ 18 each
![]() Full Synthetic Oil 10w30 K&N Filter Full Synthetic Trans Fluid / filter Change ![]() ![]() |
I had posted a couple of months ago, my experience with the "amazon" mounts.
When I used the upper and lower, and set everything proper, I could not get the motor to stop vibrating, not bad, but you knew it was there. I replaced the lower with a Chrysler mount, and when I compared the 2, there was about a 3/8 difference in the hole alignment, and the diam. of the one hole was larger on the amazon replacement. Long story short, after installing the factory unit, there was absolutely no vibration. Somewhere in this thread library are pics that I posted. Rotty |
Thread Tools | |
Display Modes | |
Motor mount | lmcs1234 | Tech & Performance Forum | 3 | 13 May 2013 10:39 am |
is my motor mount bad? | Koch | Tech & Performance Forum | 19 | 19 Mar 2012 02:15 pm |
motor mount | cllwyrc | Tech & Performance Forum | 13 | 04 Feb 2012 09:02 pm |
Motor Mount | CityGirl70 | Tech & Performance Forum | 11 | 20 May 2011 10:51 pm |
Motor mount mod. | PVO PT | Turbo Wheels/Suspension/Handling | 4 | 28 Jun 2003 02:30 am |
