Need more help! 6 O2 sensor and 2 PCM still the same issue.
Old 05 Aug 2014, 09:05 am
Default Need more help! 6 O2 sensor and 2 PCM still the same issue.
I have a 2005 Turbo PT Cruiser convertible engine VIN “E” it first start to display DTC P0031 and P0037. Changed with Bosch O2 Sensors problem remains. Tested the ground circuit at the main harness have continuity. Tested pins 2,3 and 4 to ground no short. Replaced the PCM, reprogrammed with my VIN and mileage. As soon as the engine start up same P0031 and P0037. Replace the O2 sensor again with Bosch, same issue.
I then took it to the dealer and they told me that I had a bad PCM. So I RMA the PCM and now the second PCM is giving me P0032 and P0038. I been researching all the forums site and everyone have been saying to use the OEM sensor so I replaced both of the sensor with the OEM O2 sensor and I’m still getting the same code from Hell P0032 and P0038. So the bottom line, I ran out of idea after 6 O2 sensor and 2 PCM. Any help is highly appreciated. Thanks you!
Old 05 Aug 2014, 09:45 am
LionPT's Avatar
Default Re: Need more help! 6 O2 sensor and 2 PCM still the same issue.
I replaced my O2 Sensor last month with a Bosch & the code & CEL never went out...I started reading around & found some PT's don't like Bosch...I replaced it again with an NTK than all lights & codes disappeared.
Old 05 Aug 2014, 09:51 am
Thanks, I read the same thing that is why I broke down and brought the OEM O2 sensor. I still have the same problem.
Old 05 Aug 2014, 10:13 am
last time i had an o2 code, it was in my mustang. the problem was a cracked emissions solenoid causing the car to inject too much air from the smog pump. you can't just throw parts at problems like this. you'll never fix it like that.
based on the fact that it says high voltage, not lean/rich etc, i would check the ground wire on the o2 harness for continuity.
you can check with a multimeter, there is plenty of o2 diagnostic aids for this online. if you are not up to the task, it would be cheaper to have a mechanic do it than to keep throwing parts at it.
Old 05 Aug 2014, 10:28 am
attached is the connector pinout for a 2005 turbo vin "e" o2 sensor.
ground is the same location on both connectors.
Old 05 Aug 2014, 10:30 am
Thanks, rob342.
I already tested the ground circuit at the main harness which is on pin 1 and it have continuity. Tested pins 2,3 and 4 to ground no short.
I also did this to see if it was a short to ground: I use a test light with the clip end I attached it to the positive side of the battery and with all 4 connection on the PCM disconnected. I tested the 4 pins in the engine harness. Pin #1 would light the test light which is correct since pin #1 is the ground pin, so I did pin #2, #3 and #4 and the test light doesn't light up. This tell me that the other 3 wires are not short to ground. I might be wrong with this test.
Old 05 Aug 2014, 10:36 am
rob342, I see that you use ALL DATA. I to have access to All Data. I try to follow the troubleshooting step but I couldn't do the second test which call for DRBII to actuate the O2 heater circuit and check the voltage. I would think that the dealer would have done that when I took the car to them. Instead the dealer told me that I have a bad PCM.
Old 05 Aug 2014, 10:41 am
when you measure pin 3 is the voltage over 1v?
can you measure pins 3 & 4, using pin 1 as a ground?
Old 05 Aug 2014, 12:24 pm
Pin 3 have 2.51 volts
Pin 4 have 4.10 volts
Old 05 Aug 2014, 02:03 pm
Here is the freeze frame data P0032 (MOD $10). I have no idea what Im looking at.
ABSLT TPS 25.1%
ENG SPEED (RPM) 2115
CALC LOAD 38.0%
MAP (HG) 20.7
COOLANT 203*
IAT (*F) 79
IGN AVD 36*
ST FTRM1 0.0%
LT FTRM1 -6.3%
VEH SPEED 46
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
In the recording data it show that O2S11 1.27 volt and O2S12 1.27 volt also
crankshaft position sensor issue!!!!! twincharged30 General PT Cruiser Discussions 14 27 Aug 2013 08:29 am
Weird gearbox sensor issue? Garya1682 Europe PT Forum 6 23 Aug 2013 07:23 am
cam sensor issue charles Tech & Performance Forum 1 02 Dec 2011 02:12 pm
Ignition Issue !!, Fuel pump, filter or MAP sensor? somarillw General PT Cruiser Discussions 3 17 May 2011 06:40 pm
Map Sensor Issue? presman Tech & Performance Forum 5 10 Jul 2009 03:04 pm
