Hello! My name is Fredrik and i am new to this forum. I am from sweden and my wife just bought a PT Cruiser 2001 2.0 Limited Edition.
And i have a problem... The Check Engine light is on. And it shows error code P0171. And what i have found on this forum is this: P0171 Fuel Trim System Lean Bank 1 What could it be? I have checked for leaks in the vacum lines and checked the pvc valve. So where should i begin? I have tried to read out with the obd2 outlet but i cant connect to the ecu. ( Using the Tourqe android software) When we tried the car for the first time is was no problem at all. Then we drove a couple of miles and the light come on when i bumpt in to the sidewalk. After that it has turned on after some driving. I have resetet the Check engine light, taking of the negative wire from the battery, but it still turns on after a while... Can someone mayby know what to check for next? Have a nice day! |
Greetings Fredrik
Here is a post from CREWZIN in 2009. It may offer some help. Lots of reading here on this-site specific Google search for P0171. |
Hello and many thanx! I will check the fuel cap. But witch obd2 tool should i use? I am using the bluetooth version just now. But i cant connect to the ecu with it. I also have a obd2 cable for the usb to the computer. But witch software is the best.
Have a nice day! |
![]() Quote:
Personally I not had to use a Bluetooth using a OBDII adapter cable so I am not even sure what to suggest? I have a couple special OBDII to PC programs but they are specialized and very pricy. Mainly for DATA logging and computer calibrating. Maybe another member has a suggestion or idea what you could use? You might check with your local auto parts store that I see your have in your country. Tell them that you are looking for an inexpensive Diagnostic Scanning tool for OBDII. Or if you look on Ebay or amazon for sellers in your country or who can sell to you. If you see something PM me with the info and I will let you know if it will work for you. |
Hello my friends! I have borrowed a OBD2 instrument that can connect to min car!
I have done som live reading with it to. And I wonder if one of the O2 sensor ir broken... On Idle: O2S B1S1 ( V ) 0,195 O2S B1S2 ( V ) 1.000 And this when the ignition is on but not running: O2S B1S1 ( V ) 0,000 O2S B1S2 ( V ) 0,550-0,700 I have noticed that the top one, The one above the catalyth is changed.. Have a nice day everyone! |
Thread Tools | |
Display Modes | |
Check Problem Codes Yourself! | turbomangt | General PT Cruiser Discussions | 14 | 01 Jun 2016 01:37 am |
2004 Engine misfire and flashing check engine light | fg1911a1 | General Turbo Discussions | 15 | 26 Jul 2014 06:20 pm |
Check engine & gear shift problem | sunny8088 | Tech & Performance Forum | 11 | 07 Nov 2012 08:35 am |
Check Engine | vikz | Tech & Performance Forum | 9 | 04 Aug 2011 02:25 am |
CHECK ENGINE | BORICUA | General PT Cruiser Discussions | 9 | 10 Aug 2004 07:58 am |
