Error code p0303... I know what it's not
Old 09 Aug 2014, 03:28 pm
Default Error code p0303... I know what it's not
Hey guys, I have an 07 pt base cab. I have tested compression and the 3rd is low. I have no smoke at all when driving. I have no overheating, no oil in coolant or coolant in oil. It's not exhibiting any problems that a piston ring is worn.
I have rough idle, minor loss of power of acceleration, and sometimes after the cruiser has been sitting it will crank for 5 seconds until it actually turns over.
I would appreciate any feedback.
Old 09 Aug 2014, 06:58 pm
Default Re: Error code p0303... I know what it's not
Could be a valve problem...
Old 09 Aug 2014, 09:29 pm
I recently had error code p-0301 indicating cylinder #1 misfire. Turns out that that spark plug was cracked. I also had some loss of power with acceleration that resolved after changing that all out.
Old 10 Aug 2014, 08:54 am
But he says compression is low in that cylinder - that's not something a bad sparkplug can cause.
Old 10 Aug 2014, 09:36 am
Yeah its definitely not tuneup related. When I first start the car it idles at 1000 for 2-3 minutes then when it's warmed up it's usual idle is 550-600. I don't think it is piston ring related.
Old 16 Aug 2014, 12:00 pm
My 2008 Pt Cruiser automatic 70,000 miles has the misfiring issue also. I have not checked the compression on my engine but I am leaning towards carbon build up in the cylinders. My engine misfiring started about 2 years ago starting with every 2 to 3 months with the misfiring issue coming up to now every two months with the engine flashing for a few seconds until I get the rpm's up. I have been able to get it solved for a few months each time by using Techron engine injector cleaner but now its only every 2 months. Now I am leaning towards carbon build up as I use a quart of oil every 3,000 miles. My question is whether to switch to Seafoam or Carbon Combustion Cleaner as I have read pro and cons with each one. One of the cons is that carbon combustion cleaner clogs up the O2 sensors making them fail. Any advise is appreciated.
Error p0303 after running air conditioner jamajessie Tech & Performance Forum 4 15 Apr 2014 01:17 pm
Stumpt P0303 error code Teckis General PT Cruiser Discussions 4 15 Jul 2013 03:12 am
P0303 Code - Tried Everything RoboCruzer Tech & Performance Forum 11 10 Apr 2012 10:55 pm
Code P0303 psfponies General PT Cruiser Discussions 10 29 Mar 2012 09:04 pm
Error Code P0303/Check Engine Light ohiomas Tech & Performance Forum 1 10 Apr 2011 02:47 pm
