Well, just popped my PT Cruiser middle motor mount cherry this weekend. Holy crap! What a pain the arse. Took all of two days but took picks and will post the story in a few days.
Bought the car last week and knew it needed mounts by the test drive but had no clue about the history of this problem. After reading up on the job I was on the fence to even take it on. But I pulled the prior service records at a dealer near home and found out the timing belt, water pump, head gasket, cylinder PSI readings, etc. (all related to a jumped timing belt) were done just 6 months ago. So, I figured it was worth the time. NOT REPLACING A BUSTED MIDDLE MOTOR MOUNT DURING A TIMING BELT CHANGE IS CRAZY! Anyway, replaced all three of the motor mounts and the trans mounts, radiator too while I was at it. But when I first started the car, it revved WAY up to the extreme. All the way. Checked the throttle linkage and nothing seems wrong. I'm guessing a vacuum leak since so much of it was apart and the motor shifting during my monkeying the middle mount out. Any one I should start with? This site has been invaluable as well as some YouTube videos. Gotta go to bed. My brain is mush from this Crazy Chrysler. ![]() Last edited by lenwood; 10 Aug 2014 at 11:09 pm. |
If throttle cables are good. It's like nitro said. Check the big vac lines till you find the end that's off.
Throttle cable after all. Just needed to see it in the daylight with a fresh pair of eyes. One of the cables was pulled out too far and did not seat back into the groove properly.
Thanks for the reply ![]() |
Thread Tools | |
Display Modes | |
Motor mounts going bad | wasmussen | General PT Cruiser Discussions | 31 | 07 May 2015 07:23 pm |
Revving a little too high & not dropping quickly | ProperTricky | Tech & Performance Forum | 7 | 16 Jul 2014 08:45 am |
Replaced W/P, Now Revving High/Low in Idle | andrew234 | General Turbo Discussions | 5 | 14 Aug 2013 10:59 pm |
Motor Mounts | pkpt04 | Tech & Performance Forum | 14 | 21 Aug 2009 10:02 pm |
PT MOTOR MOUNTS HELP !! | BARRYPT | General PT Cruiser Discussions | 2 | 18 Jan 2008 12:44 am |
