Fuse blowing out for brake lights
Old 11 Aug 2014, 05:58 am
Kar Kar is offline
Unhappy Fuse blowing out for brake lights
I have a 2006 PT Cruiser. I am blowing out a #11 fuse and the brake lights are going out, and also, when this happens, it's hard to get my gear shift out of park, even while depressing the brake pedal. I replace the fuse, it works for about 5 minutes or so, and blows again. Please, any suggestions? I takes me 1/2 hour to get to work and without brakes, I do not want to get hit!
Old 11 Aug 2014, 07:38 am
Default Re: Fuse blowing out for brake lights
Take the rear brake lights out and check for frayed wires or water inside the lens, anything that would cause the circuit to blow the fuse.
Old 11 Aug 2014, 08:41 am
I believe you have to step on the brake pedal to move out of park - that points to a faulty brake switch if getting it out of park is difficult. Switch could also be your fuse problem...
BLOWING FUSE 13 hillbilly678 General PT Cruiser Discussions 7 04 Jul 2012 04:45 am
Radiator fan blowing relay fuse flamingojohn Tech & Performance Forum 5 05 Oct 2010 06:57 am
fog lamp fuse blowing smilanatu Tech & Performance Forum 13 19 Jul 2009 11:07 am
Fuse Blowing Zoomer General PT Cruiser Discussions 2 19 Jun 2009 11:48 pm
HEATED SEATS (FUSE KEEPS BLOWING) BIGZ General PT Cruiser Discussions 9 16 Feb 2009 10:39 pm
