02 Cruiser No spark
Like Tree4Likes
Old 12 Aug 2014, 08:19 pm
Default 02 Cruiser No spark
Have an 02 Cruiser 2.4L that we did the timing belt on, during that we did the water pump and head gasket. There was nothing wrong with the car when we started this project, it was just something that needed done. 130k miles on the car. We put everything back together, plugged everything back in, now we have no spark whatsoever. The battery was disconnected during this whole process. I have checked all fuses, swapped the ASD relay, replaced cam sensor and crank sensor, replaced coil, checked all grounds, triple checked all connections and grounds. According to my Snap-On scanner there are no codes or stored codes. I can't figure out what is going on. Any help would be greatly appreciated. From reading through here, I've learned there is no ignition control module, it's all done through the PCM. The fuel pump is working fine, I just have no spark. Could something have happened with from the battery being disconnected??
Old 12 Aug 2014, 08:28 pm
Default Re: 02 Cruiser No spark
I have read that there are 2 connectors that can be mis-connected. It's happened to a couple of people.
I hope someone else chimes in with more detail than I have.
rob342 likes this.
Old 12 Aug 2014, 08:42 pm
I just did some reading and ill have to check in the morning. The TPS and coil have the same connector and may have been swapped when it was all put back together. EDIT: Sitting here at the computer, looking at pictures of the TPS and Coil, they have different connectors that wont allow them to be swapped.
rob342 likes this.
Old 12 Aug 2014, 11:35 pm
Its possible to swap the cam sensor and coil connector
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 13 Aug 2014, 12:07 am
Re check for DTCs. If the PCM is connected and it has not failed there will be codes. Snap on diagnostic scanners are able to check readiness status with a no start ignition on you will show area's of alert.
The battery being disconnected during your work and reconnected later has nothing to do with the engine not starting. It may erase your radio station memory.
A perfectly running PT Cruiser if you pill all the primary lead or up plug the coil initiate a start and than reconnect everything you will activate DTCs even though you reconnect the coil and replaced the plug wires. It is how the OBDII system works.
Old 13 Aug 2014, 03:00 pm
Alright, I swapped the CAM sensor harness with the Coil Harness and it fired right up. I think with them being switched like that it burned up the CAM sensor because that is the code it is throwing now. Thanks for your help
Jautowizz likes this.
Old 13 Aug 2014, 03:26 pm
I think the designer who thought that 2 identical connectors that could reach was a good idea should be forced to walk everywhere.
Glad my hunch was right, and sorry I didn't recall it was cam sensor and coil...
Old 19 Aug 2014, 01:21 pm
P0340 code after replacing the cam sensor twice now. Still won't go away for some reason and according to my scanner there is no signal at all from the cam sensor. What's next?
Old 19 Aug 2014, 01:45 pm
LionPT's Avatar
Check the cam plug & wiring going down the side of the block.
Old 28 Aug 2014, 04:32 pm
Ok. Sorry about the delay. All the wiring looks great. With the cam sensor harness unplugged I have 2V at the power wire and 5V at the signal wire with the key on.at the crank sensor with the harness unplugged I have 8V at the power wire and 5V at the signal wire with the key on. When I plug them in and start the car I get 2.2V at the cam sensor power wire and 0.18V at the signal wire. Still not sure whats going on but it keeps throwing the code immediately.
EDIT: All this time I have had no signal coming from the cam sensor while running. So I tried unplugging the crank sensor and cranking it over, I finally got a good signal from the cam sensor. Now I'm going to try a new crank sensor.
05 PT Cruiser, No start, No spark Rya Tech & Performance Forum 3 01 Dec 2013 03:30 pm
07 Cruiser with no spark???? halfwaydecent Tech & Performance Forum 3 10 Feb 2013 02:09 pm
07 pt cruiser no spark or injector pulse lilblkshp Tech & Performance Forum 10 14 Jan 2012 09:54 am
01. pt cruiser no spark gjason49 Tech & Performance Forum 1 03 Jul 2011 04:08 pm
Help no spark 2002 pt cruiser zackkbcobra Tech & Performance Forum 14 27 Jun 2011 03:27 pm
