Only getting 8psi?
Old 13 Aug 2014, 09:33 pm
Default Only getting 8psi?
I posted here a while ago about a boost problem after the timing belt got replaced. A few days ago my friend put a pressure tester on my intake and found a boost leak. We fixed that and the boost gauge at the same time. Went for a test drive, but I am still only pushing 8psi. (holds steady and does not fluctuate) . Prior to the timing belt I was pushing 15psi. The car sounds like it was to go, but doesn't.... Any thoughts as to what might cause this?
