PT's fuse box
Old 14 Aug 2014, 07:50 pm
Default PT's fuse box
I have a 2006 PT Cruiser and need a fuse box.
when I call salvage yards they talk like only a 06 will fit my car.
when I look on ebay they show fuse box is fitting 2006up to 2010.
does anyone know if I can use a different year model fuse box
Old 14 Aug 2014, 10:02 pm
Default Re: PT's fuse box
Rockauto shows them for 2006-09, they are called TIPM, I didn't check to see if they were the same p/n. I believe they have to be programmed to the car. Someone was just saying they installed a used one off a wrecked car and his airbag lites came on in his car.
'06 Cruiser Touring, 157k, Cool Vanilla, Auto
Old 15 Aug 2014, 01:56 am
Before you purchase a replacement TIPM (FUSE BOX) you should check all the fuses (twice) then remove the TIPM and check the wiring connectors on the underside for any sign of bad connections, burned, melted, loose connections or corrosion (Copper wire turning green)
You probably could ruin a TIPM by using a pressure washer to clean you engine, they are not sealed like the PCM.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Fuse box bad? 06_Cruiser Tech & Performance Forum 3 02 Sep 2013 02:00 pm
no Fuse problem and not iod fuse ptcarter Tech & Performance Forum 24 09 Jul 2013 03:21 am
Fuse Box -- Need Help PtPtPt Tech & Performance Forum 12 22 Jun 2013 09:43 am
HELP with Wiring Fuse 7 (No feed to fuse) No A/C, Electric Windows, Rear fogger??? ptcruisershoreham General PT Cruiser Discussions 3 08 Mar 2011 08:06 pm
No fuse??? Ironman Tech & Performance Forum 0 07 Dec 2009 06:30 pm
