help with cam sprockets
  • 1 Post By Busted_PT
Old 17 Aug 2014, 08:00 am
Default help with cam sprockets
I am replacing a leaking water pump on my 03 2.4l engine. I can't get the cam pully bolts to loosen. I am thinking to make a holder as pictured in my manual. My impact with 10gal compressor won't get it. Any suggestions?
Old 17 Aug 2014, 12:15 pm
Default Re: help with cam sprockets
You can use a wedge rubber door stop or wooden shims between the cam gears to loosen or tighten the bolts. I would also recommend that you take pictures to remind you what goes were. Also take picks of the finial alignment before you cover it up to verify it later if it comes into question. I know it's in time becomes, I think it's in time. Picture doesn't change or forget. Start with it with it just hanging there to make sure everything is good. Here are some useful threads.
Replacing the timing belt 2.4L (without a lift!) -Detail instructions
HARMONIC BALANCER & CRANK SPROCKET REMOVEL AND INSTALL TOOL AND TIPS!!!!
Handy_Cruiser likes this.
Old 17 Aug 2014, 06:13 pm
Angry Re: help with cam sprockets
Thanks for the reply busted. I did make a spanner tool today
with a couple 8mm bolts threaded into it. It worked like a charm. Great suggestion taking pictures. I am original owner and did the timing belt and water pump at 100k. I think I will change both again now at 157k. They Both look OK I think just the o ring seal was leaking. Not sure but the leak was getting progressively worse for about 6 months. Water was leaking below the crank, steady flow once the pressure was up. Finally car became undrivable.
Great repair threads. They really help people like me.
Old 17 Aug 2014, 06:58 pm
Thank you, That was my first as well. Studied up on it here as well. lots more stuff in the how to's in the tech and performance section. If you haven't found that yet. Sounds like a good plan.
timing belt coming off the cam sprockets tmikes Tech & Performance Forum 38 10 Feb 2014 04:07 pm
Help with torquering cam sprockets! shespt General PT Cruiser Discussions 13 06 May 2013 02:52 am
cam sprockets twrh111 Tech & Performance Forum 1 12 May 2011 07:51 pm
