engine
Like Tree5Likes
Old 18 Aug 2014, 04:16 am
hal hal is offline
Default engine
Hi there I have bought a 2001 pt cruise limited addiction I have a engine that miss and back fires at high revs can someone can help me thank you from hal ....
Old 18 Aug 2014, 08:20 am
Default Re: engine
How many miles does the car have on it and is the engine light on? If so do you have the trouble codes on it?
Old 18 Aug 2014, 08:41 am
Default Re: engine
Start with spark plugs and wires.
Old 18 Aug 2014, 09:58 am
Default Re: engine
Old 18 Aug 2014, 10:26 am
Handy_Cruiser's Avatar
Default Re: engine
Originally Posted by NitroPT View Post
The was a good one.
hal likes this.
Old 18 Aug 2014, 10:32 am
Default Re: engine
1. Introduce yourself in the new members section.
2. Scan for trouble codes. That will likely tell you where to begin.
3. If you don't have access to a scanner, go to Autozone or Advance and have them scan if for you for free. Instead, you can also do the "Key Dance" get the codes from the odometer screen. But you will still have to look them up. You can learn how to do the Key Dance here:
My Key Dance video
hal likes this.
Old 19 Aug 2014, 04:22 am
hal hal is offline
Default Re: engine
Ok check code all zoro and done ...... odometer is 204,307 I well check plugs and leads next
Old 19 Aug 2014, 04:36 am
hal hal is offline
Default Re: engine
Old 19 Aug 2014, 08:22 am
Default Re: engine
The factory wires and plugs are well known to be junk and many people have vast improvements after replacing them.
hal likes this.
Old 22 Aug 2014, 10:31 pm
hal hal is offline
Thumbs up Re: engine
Thankyou mate it was plug and wires it gos like a rocket now
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
Converting 2002 engine to a 2003 engine - ECU RomanSouthAfrica Tech & Performance Forum 2 08 Apr 2013 04:33 pm
Can I swap a 2001 w/egr engine for a 2002 engine w/o egr? cas0918 General PT Cruiser Discussions 5 15 Feb 2013 11:58 pm
Pt Crusier engine change with a neon engine? reepos1 Tech & Performance Forum 2 09 Nov 2010 11:21 pm
Can 2001 Engine be replaced with Newer Engine harleysforfun General PT Cruiser Discussions 1 07 Aug 2009 01:38 pm
