Problem and no error codes
Old 19 Aug 2014, 02:05 pm
Default Problem and no error codes
All the lights on the dash are coming on and off while driving. Used the ODBII and there are no codes.
I checked for shorts and found nothing. The battery is tied down and does not move. Any ideas on what this could be?
Any help would be appriciated. (would the alternator do this without throwing a code).
Oh... this is a 2006
Old 19 Aug 2014, 05:20 pm
Default Re: Problem and no error codes
I have had the same issues with my 2006. Today the check engine light came on. I couldn't pull the codes myself (the on off trick didn't work). The dearlership I took it to said it was a PCM issue; specifically the TCM which will require the entire PCM to be replaced. Was quoted $1500???
Error Codes Error lilcruiser Tech & Performance Forum 2 10 May 2012 05:34 am
error codes??? Turboguy85 Turbo Performance 2 22 Sep 2010 05:15 pm
no error codes lt4supr Tech & Performance Forum 4 14 Aug 2009 07:34 pm
i got error codes what do they mean feefeethaflee Tech & Performance Forum 3 31 Jul 2009 08:41 pm
