2006 Cruiser Turn signals and Hazards
Old 19 Aug 2014, 08:12 pm
Default 2006 Cruiser Turn signals and Hazards
I have a 2006 Cruiser, base model. During a recent trip, all my turn signals and my hazards quit working. The bulbs are fine. We've tried replace the Multi-function switch, but that didn't work. I find it hard to believe that all the relays, if I could even find them, went at the exact same moment and I know everything went at once.
Does anyone have any ideas? I've tried searching this forum, but no luck there. Everyone talks of the MFS, but that is not the issue with my car.
Help, please?
Old 19 Aug 2014, 08:14 pm
Default Re: 2006 Cruiser Turn signals and Hazards
blown fuse maybe? might be a possibility
Old 19 Aug 2014, 08:15 pm
The 2006 does not have a fuse for the signals or hazards. I would like to meet the person who thought that was a good idea. I have a few choice words to say to them.
Old 19 Aug 2014, 08:19 pm
To be honest, I just guessed and don't really know if they had fuses or not :S
Old 19 Aug 2014, 08:54 pm
I have been reading about bad light bulb sockets but on both sockets? Maybe a short somewhere or a bad ground wire contact? Are you measuring getting any voltage at the sockets with the light bulb out with the turn signal on?
Old 19 Aug 2014, 08:59 pm
Also is the turn signals working in the dashboard?
Old 19 Aug 2014, 09:02 pm
rckstein's Avatar
Help, please?
Try disconnecting the battery and resetting the PCM. Search this forum for that procedure. A while back I had a similar situation with my PT where it had no turn signals and only the high beams worked. After disconnecting the battery, that fixed everything and the problem has not happened since. Can't hurt and won't cost you anything.
Old 19 Aug 2014, 09:22 pm
There might be a combination flasher for both the turn signals and the hazards. It should be plugged into the MFS on the steering column. This would be the first thing I would replace before doing the other two suggestions above.
Old 19 Aug 2014, 10:47 pm
Ray_Dockrey's Avatar
There is no flasher as it is built into the TIPM or at least that is where I think it is because I can't find one anywhere. I know it's not part of the MFS. Disconnecting the battery will reset the TIPM and if that doesn't fix it then a dealer will have to scan the TIPM and see if it can be reflashed or if it needs replaced.
Old 20 Aug 2014, 12:34 am
Ray
Thank you for your more accurate information on the flasher. According to the Haynes Manual 2006 Pt Cruiser and up does not have the flasher. I now agree with what Rays recommends.
No turn signals. Fuse Blows when Hazards turned off JerryJovi Northwest PT Forum 1 15 May 2014 08:16 pm
no turn signals Darkchylde Tech & Performance Forum 13 29 Mar 2014 10:44 am
INDICATORS TURN SIGNALS HAZARDS PATGAS Tech & Performance Forum 9 29 Oct 2013 04:59 pm
Hazards and Turn signals out. KrisBo Tech & Performance Forum 4 29 Dec 2011 05:23 pm
No turn signals, wipers, washers for 2006 pt thundert79 General PT Cruiser Discussions 4 13 Dec 2008 09:55 pm
