headlight problem
Old 20 Aug 2014, 05:09 pm
Default headlight problem
I was driving my cruiser last night and my low beam headlights stopped working. I had to drive the rest of the evening with my high beams on. Is that the headlight switch or is it a relay?
Old 20 Aug 2014, 05:24 pm
Default Re: headlight problem
On your 2001 in the interior fuse block you have two silver Circuit Breakers on top of the fuses. The left one is for the Power Windows, the right one is for the head lamps. You also have fuses #19 and #20 for the individual head lamps but I doubt if both fuses blew at the same time. Check out that C/B (Circuit Breaker).
Old 20 Aug 2014, 11:20 pm
Turns out it was the switch ONCE AGAIN. Luckily I replaced it just a month or so ago with a lifetime warranty one from o'riellys. They replaced it for free.
Headlight switch Problem ksrcrider Interior Accessories Forum 3 19 Jan 2012 03:48 pm
Headlight Problem PTColossus General PT Cruiser Discussions 5 22 Nov 2011 11:25 pm
help,headlight problem :( drsarman Tech & Performance Forum 3 13 Sep 2010 07:21 pm
Headlight Problem Madturtle Tech & Performance Forum 2 04 May 2009 08:05 pm
Headlight Problem jmack General PT Cruiser Discussions 21 23 Nov 2007 05:58 pm
