2007 fan relay
Like Tree2Likes
  • 1 Post By MNTEGRA01
  • 1 Post By ptcruisersteve
Old 22 Aug 2014, 12:03 pm
Default 2007 fan relay
Chasing down issues with my a/c. I think the relays might be bad. Are they standard spdt relays or are they special (other than the housing)as the dealer is insisting or can any old relay from the parts store?
Old 22 Aug 2014, 12:24 pm
Default Re: 2007 fan relay
CHECK OUt this NAPA part number, AR272, or AR272SB
I had very similar problem. engine idles down almost stalls with AC on, and blows HOT. might have built up too much pressure in a hose and also blown out a AC line.
check out this link...
Cooling Fan Failed
06 PT. Base auto. Sunroof. ... whatever. . Not sure... step-moms car.
Old 22 Aug 2014, 01:27 pm
Thanks. Luckily the compressor popoff valve worked. Tried the relays will no luck. Getting new fan installed today.
Old 22 Aug 2014, 07:27 pm
If you are installing the cooling fan yourself check the wire connector as sometimes the connector is bad when you buy a dorman 620-052 fan assembly.
Old 25 Aug 2014, 06:07 pm
Fixed... Although next time I'll do it myself took him 20 minutes and $50 lol
Which relay is which on fan? Skytex Tech & Performance Forum 12 31 Jul 2014 08:05 am
Hid kit relay beakerss Exterior Accessories Forum 6 03 Oct 2011 09:50 pm
A/c relay bigdee Tech & Performance Forum 0 22 Aug 2011 10:05 am
Relay bruent General PT Cruiser Discussions 2 27 Sep 2008 06:52 pm
A/C Fan Relay? KingKole02 Tech & Performance Forum 7 22 Mar 2006 04:20 pm
