A/C not working after timing belt replaced
Old 23 Aug 2014, 03:52 pm
Default A/C not working after timing belt replaced
My timing belt broke on my 2002 PT cruiser touring edition. My husband replaced it and did not disconnect the A/C line. I have been driving it for the past 2 weeks and the other day I decided to put the a/c on because it was pouring. This was the first time I turned it on since having belt fixed and it blows hot air out. It worked perfectly fine before the belt broke. My husband looked and pushed on the valve and there is no freon. We do not understand why there would be no freon if it was not touched? And what are the possible reasons for this happening?
Old 23 Aug 2014, 04:05 pm
Default Re: A/C not working after timing belt replaced
I have heard that when the motor gets raised up and down when you are replacing the timing belt, it can sometimes hook the A/C hose on to the radiator fan shroud and tear it if the motor is raised too high.
If that is not the problem it might be the connector on the top/back of the compressor is leaking. Let us know what you find out.
Old 23 Aug 2014, 04:20 pm
Also I heard that the A/C system needs to be evacuated and disconnected to change out the power steering pump and then recharged. The power steering pump along with a lot more must be removed to do the timing belt but I don't know what year PT Cruisers this applies to. Was the power steering pump involved?
Old 23 Aug 2014, 04:42 pm
The power steering pump was not changed out but it was disconnected in order to replace timing belt.
Old 23 Aug 2014, 05:03 pm
Power steering pump only needs to be unbolted to do the timing belt.
If you raie the motor to much to do the belt it can stress the connection that is bolted together on the AC lines and that can cause you to loose your freon (134a) In this case guessing is not going to solve you problem. Your going to have to take it to someone knowledgable that works on AC systems to find the leak. You cannot just add a charge to it and hope it works because the Hi side and low side pressure will be out of range, you first start with a vacuum and see if it holds.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 23 Aug 2014, 07:07 pm
You can inject dye into the A/C system and use an ultraviolet light to see where the leak is coming from but if you are not familiar with the procedure or comfortable working on A/C you are better off taking it to an expert that would ensure no more Freon is leaking into the atmosphere.
Old 24 Aug 2014, 08:19 am
He did jack the engine up pretty far so that makes sense why I would have lost freon. I guess I will have to take it to someone to look at it. Thanks for the help :-)
Old 24 Aug 2014, 09:28 am
The A/C suction line that comes off the top of the compressor will fail at the crimp where rubber connects to metal if you even look at it too hard. I have had to replace mine twice, once all I did was replace the thermostat. It will then bleed the system down in a couple days time.
Old 24 Aug 2014, 09:54 am
I was concerned about putting stress on the A/C hoses myself when I was moving the radiator forward to get the radiator fan out. I try not to move any other parts other than what I am working on but with these newer cars its a challenge.
Old 24 Aug 2014, 05:08 pm
Just curious. Did the timing belt break while driving? Glad your engine wasn't damaged.
Also wondering how many miles might have been on that belt. I know a lot of people don't replace at 100k miles.
Hope you get the AC fixed easily.
2001 timing belt replaced Quits General PT Cruiser Discussions 15 10 Apr 2014 02:22 pm
replaced timing belt but no rpm cbpres Tech & Performance Forum 1 18 Jul 2012 12:08 pm
Replaced My Timing Belt! A Few Observations FWIW Poncho Villa Tech & Performance Forum 1 19 Apr 2010 07:13 am
Replaced timing belt turbomangt General Turbo Discussions 0 06 Oct 2008 07:27 am
