2005 ignition switch
  • 1 Post By RacerX125
Old 24 Aug 2014, 10:33 pm
Default 2005 ignition switch
I have a 2005 pt convertible, turbocharged engine. The key will not come out of the ignition switch unless you jiggle the shifter and steering column, turn the key on and off and maybe it will come out. I also noticed it will start in drive sometimes[ found that by accident]. Any help appreciated Thank you in advance, nicky1
Old 25 Aug 2014, 10:06 am
Default Re: 2005 ignition switch
You need to have the ignition switch replaced.
Old 25 Aug 2014, 11:19 am
Sometimes the shiftinterlock cable stops releasing correctly which locks the key in the cylinder until the cable detects that the shifter is in park even though you are in park sometimes the cable can stick
LionPT likes this.
Old 25 Aug 2014, 03:11 pm
harrym's Avatar
This happens to me in my '05 (sort of). Sometimes when turning the key off, I can't get it to go to the position where the key will come out. I can then either push down on the brake and it will then turn, or I can shift out of Park and then back in and it will turn. But it is sporadic, and I've not tried to start it in Drive. I suspect the interlock cable.
Harry
2005 Touring n/a - Cool Vanilla with J&J vertical billet grille, PTeazer tail lights, Chrome wheels and Baby Moons.
Old 25 Aug 2014, 05:09 pm
Thank you all for the help. I worked on Cat equipment... hate working on cars unless they are 40 yrs old.
Ignition switch lt4supr Tech & Performance Forum 10 21 May 2016 06:28 pm
Ignition switch?!?! Lolo376 Tech & Performance Forum 19 23 May 2014 11:20 am
Ignition Switch BMAC1206 General PT Cruiser Discussions 10 22 May 2012 03:27 pm
2005 PT Cruiser Ignition Switch thecrowx General PT Cruiser Discussions 0 28 Aug 2010 02:54 pm
Possible Ignition Switch? bkarr Tech & Performance Forum 4 20 Jul 2008 06:25 pm
