radiator replacement
Like Tree3Likes
  • 1 Post By JoeX
  • 1 Post By Handy_Cruiser
  • 1 Post By rob342
Old 29 Aug 2014, 06:54 pm
Default radiator replacement
Hi,
I have a 2002 touring edition and need to replace the radiator....I have read that you do need to empty the ac coolant and I have read that you do not. Any help would be greatly appreciated. It is a manual transmission.
Thanks
Mark
Old 29 Aug 2014, 06:59 pm
Default Re: radiator replacement
i had to almost take out my radiator to change a sensor. i would suggest draining it or you WILL have coolant everywhere. it is a pain but worth not having coolant on the floor while working. also there is a handy thread on here about bleeding the system and using HOAT over the green stuff. check those out for when you finish changing it.
2005 Purple Pt Touring 130k Still Running Strong
New timing belt and water pump at 130k.
Old 29 Aug 2014, 07:07 pm
sorry misread that thread. as far as the AC goes, i would have no idea on that.
Old 29 Aug 2014, 07:16 pm
Handy_Cruiser's Avatar
I believe you can replace the radiator without losing all your freon. Sometimes the manual will call for this when it is not always necessary. I never break the AC system open unless I find there is no other choice. Recharge is just too expensive even if you do it yourself.
Old 29 Aug 2014, 07:22 pm
Its a little tight getting the two bolts out on each side but very dooable.
Leave the AC alone, it wold be an unnecessary expense.
Radiaors are about $115
Handy_Cruiser likes this.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 30 Aug 2014, 12:55 am
Just remember, when it comes to radiators you always want to go really really BIG!
PS: That's an oversized Chevy truck radiator. To use it on a PT Cruiser you would have to cut the whole nose off the car.
rob342 likes this.
Old 30 Aug 2014, 09:30 am
yea i upgraded my PT to this:
required a little trimming here and there. works great.
Old 30 Aug 2014, 09:42 am
Originally Posted by marklynn View Post
Hi,
Thanks
Mark
i did not evacuate the AC lines when i put my $54 radiator in. my car is manual too. it's not a bad job at all. took me 1 hour 40 minutes total
click here i made an animated picture of the job:
anybody try the $54 radiator
Radiator Fan Replacement Chaylt Turbo Performance 10 05 Sep 2013 07:16 pm
Radiator replacement aword Wheels, Tires, Suspension 1 05 Sep 2013 07:02 pm
Radiator Replacement - Anything Else While I'm in There? bfdill Tech & Performance Forum 4 16 Feb 2013 04:39 am
Radiator Fan Replacement rcalzadilla Tech & Performance Forum 5 03 Jul 2012 09:46 am
replacement radiator sandylolee Turbo Performance 1 05 Jul 2009 01:23 am
