'02 will not stop overheating
Like Tree7Likes
Old 29 Aug 2014, 08:21 pm
Angry '02 will not stop overheating
Let me start by saying I live in Texas.
We've replaced the entire cooling system and tested for a blown head gasket..
All tests come out negative for the head gasket.
We've replaced the water pump, timing belt, radiator, coolant flush, radiator cap, fan, fuses, hoses, thermostat, checked oil and transmision oil.
It will not overheat sitting in idle at park but after I leave it wi start to overheat and I have to run with the heater on. If its cold and I have to drive, I have about 20 minutes before it over heats. Whether if I'm sitting at a light it will overheat, if I am running on tge highway its still running hot. It cools down off and on depending on if I have thee heater blasting and how much I'm using the engine.
I have tried everything that I know, please help before I set the damn thing on fire.
Old 29 Aug 2014, 08:27 pm
Handy_Cruiser's Avatar
Default Re: '02 will not stop overheating
When filling with coolant, are you using the air bleed screw beneath the thermostat housing to remove the remaining air?
Have you checked the fan? The fan should run all the time. It has two speeds.
How did you check for a blown head gasket? A pressure test often does not work. A chemical test is more definitive.
Also, welcome the forum from the great sovereign state of Arkansas!
I don't see anything about testing the radiator fan. It has two speeds and both need to be working to keep the engine cool.
LionPT likes this.
Old 29 Aug 2014, 10:53 pm
When I replaced my fan I checked the old one. I used small jumper wires to test it. The high speed was out. The low worked great. So if I was driving at speed it would be ok. But when I stopped it would get hotter then the fan would stop running. I would say check that first. I got a replacement motor with lifetime warranty from autozone for around $80. Now it runs great. That would be my guess if bleeding the system does not fix it.
harrym likes this.
2005 Purple Pt Touring 130k Still Running Strong
New timing belt and water pump at 130k.
Old 29 Aug 2014, 10:57 pm
Yes, we used the bleed screw and tested both high and low settings on the fan. The fan has been tested for both modes and it kicks like it needs to.
We checked for the blown head gasket with the sniffer test, chemical and pressure, all were good.
We cleared out the radiator and checked for leaks, we could find nothing.
We're using a 50/50 mix of coolant and water.
Old 29 Aug 2014, 11:28 pm
Are you usin the HOAT or the green stuff? HOAT is what is recommended. The green stuff, from what I've read on here, can damages the system.
Old 30 Aug 2014, 12:42 am
This is only a problem if the original orange/pink Duracool antifreeze is mixed with a few of the older green antifreezes. It causes a particulate to form that can clog up the radiator and engine water jacket. As long and the cooling system has been thoroughly flushed, any type of antifreeze can be used. And today, most name brand antifreezes are compatible no matter the color. In the particular case of the PT in this thread, a stopped up radiator (for what ever reason) might be one possible cause of the symptoms described.
Twotonpaperweight, has the cooling system been flushed and are your sure the radiator is not clogged up? Assure, the thermostat is not sticking. Sometimes, even new thermostats will stick. When I work on cars with problems like this, I often remove the thermostat, put the housing back on without it, and then flush the cooling system thoroughly. Then I just run water for coolant until I have solved the overheating problem. Plus, you can often better judge how well the water is circulated this way. With a stopped up radiator, there will be a very slow flow while a system with no thermostat will flow rapidly.
And one more thing. If you try all this and still have no joy, you might run a chemical test again. Every time the engine overheats, there is a chance that the gasket will go. Once you eliminate the easy and probable issues, you may have the revisit that. On truck engines way back in the day, I've seen a very slightly blown head gasket fool some pretty good mechanics for a long time.
Old 30 Aug 2014, 11:56 am
... problem if the original...antifreeze is mixed with (other) antifreezes. It causes a particulate to form that can clog up the radiator and engine water jacket....
Ahah! I am not alone in my thinking. We see many questions and reports here about overheating problems.
Some, especially the "I just bought a...overheats" posts suggest to me that there may be many older used cruisers around with engine-block hardening of the cooling system passages caused by mixed incompatible anti-freezes.
If a crud of coating in the block reduces water flow, efficiency is reduced.
If the crud has insulating properties, worse yet.
Old 01 Sep 2014, 12:55 pm
As far as the thermostat and flush go yes, we did exactly that a few days ago. Removed the thermostat, checked it, flushed the brand new radiator.... And after that we did do the chemical test again.
We have exhausted the possibilities for the cooling system, having replaced or tested all of it.
We have tested several times for the blown head gasket over the past 2 months, I doubt it is blown but at this point I wish it was, just so I could fix the thing.
Old 01 Sep 2014, 01:18 pm
just kinda shooting in the dark here. you may try running straight coolant no water to see if that helps at all. my dad had an old truck that if it had water it in at all would overheat. straight coolant ran perfect. that may be an option.
Fan Won't Stop Running jeremysaal General PT Cruiser Discussions 1 10 Jan 2012 11:00 pm
04 PT seems to wat to die after coming to a stop barry8108 General PT Cruiser Discussions 1 17 Nov 2010 09:02 pm
Jolted to stop Jetcab Tech & Performance Forum 4 03 Nov 2004 12:55 pm
I can't stop, somebody help me!! Mike-in-Orange Exterior & Interior Styling 8 08 Mar 2004 04:38 am
