As an EXTREMELY general rule, slow start when hot is a bad starter. Slow start when cold is a bad battery. Again, this rule is very general but offers a good place to start.
Luckily, bad batteries that do this usually show low voltage under a load and can be easily detected when tested at a parts store. Take your PT to Autozone or similar and have them do a free load test on the battery. On the fog lights, if you have no fog lights, there is a good chance that the fog light fuse has already been pulled in the past since failure of the multifunction switch usually make them stay on all the time. Check that first. To fix the problem, you may need to either to either replace the multifunction switch or repair it. Here's a link to how I repaired mine. The "Handy" Aluminum Can Mod To Fix Fog Lights.
![]() Last edited by Handy_Cruiser; 01 Sep 2014 at 02:01 am. |
Handy did you noticed he mentioned it takes several turn for the car to start? Wouldn't that mean like a bad fuel pump? someone made a thread about this that the car will take several turn to start.
He said it turns slow. That indicates a possible battery or starter issue. And often a slow turning engine will take a few revolutions to start. Checking the battery first is the most probable and easiest place to start.
![]() Last edited by Handy_Cruiser; 01 Sep 2014 at 02:08 am. |
I recently went through a similar situation with my PT, and it ended up being the fuel pump. Certainly the battery would be the easiest and cheaper part to check and/or change first, but if that doesn't help, then you should consider the fuel pump. My PT would always experience the hard-start-on-a-cold-engine where it would crank for an extended period of time, then finally start. After the pump was replaced, starts right up, no hesitation, no long cranking!
hey guys this may be a stupid question, but here goes. would air in the fuel system cause this to happen? i remember my dad had an old pickup that did tht until he checked the system. once the problem was fixed it fired first time, everytime. had a cracked hose that allowed air in.
Try this in the morning
Turn the key to on to let the fuel pump build pressure several times before you try to start the car. If it starts up without cranking much, you probably found the problem.
Addicted to Mopar You can tell how old I am.. 65 Dodge Coronet 6 cyl 2dr Post 66 Ply Satellite with 273 engine swap to 69 340 4spd 70 340 4spd Dart Swinger "Those were the days my friend" 73 Charger SE Had a few Vetts on the way 69, 85 Several Neons some flips 01 Sebring flip Cruiser's 01, 220K Gone to a new home Cruiser 03 133K Gone to a new home Cruiser 06 110K Project Gone to new Home Cruiser 05 Ltd 120,809 bought with broken belt Oct2015 May 16 Resurrected to once again roam the streets. 20 Miles South Of Pittsburgh |
I replaced the battery recently and cleaned the terminals throughly.
The foglights have always work fine, so the fuse is there. And as far as the fuel pump, wouldn't it do the same or worse once the Engine warms up? I'm leaning towards the MFS . I think that sucker somehow shorted and is Draning the battery overnight. I will get a new replacement part soon. Hopefully that's it. You guys are the best... ![]()
William____ 2004 Bright Silver PT Cruiser Turbo GT H.O ![]() |
Well..for the sake of closure, after replacing the MFS the slow starting went away completely.
It turned out to be the fog-lights switch that was creating a parasitic draw on the battery overnight. No more slow starts. ![]()
Thread Tools | |
Display Modes | |
Upon Cold Start in Cold Weather, Loud Noise?? | paulrosenthal | Tech & Performance Forum | 33 | 01 Oct 2014 09:55 am |
Slow start when cold | PTJunkie | Tech & Performance Forum | 11 | 29 May 2013 08:41 pm |
JERKING WHILE BRAKING AND SLOW STARTING WHAT COULD THIS BE?? | PTCHANDLER | General PT Cruiser Discussions | 2 | 09 Oct 2011 08:23 pm |
slow starting | thumperz | Tech & Performance Forum | 3 | 29 Nov 2009 12:38 am |
Miss at idle when starting cold?? | mjb457 | Tech & Performance Forum | 1 | 14 Jun 2007 09:46 am |
