Overheating issue
Old 01 Sep 2014, 11:57 am
Clayman1000x's Avatar
Talking Overheating issue
I recently bought a 2002 PT Cruiser, base model, 198k miles with some front end damage (bought it like this, $1000.00, see pics in my profile here on this site) basically bending the Radiator, Trans Cooler and the AC Condenser, I'm having an overheating issue again, I have since replaced:
1. Radiator
2. Trans Cooler
3. Cooling Fan
4. Alternator Belt (also had an issue with starting)
5. Battery
6. Power Steering and AC belt
7. Both Rotors and Pads (Not related to overheating issue)
I couldn't figure out where the coolant was going because it overheats regularly, depending on use, and if I fill it and rebleed it, it will run great for a few days of driving to work and back.
I drove to Menards the other day and got down and looked underneath after I got done inside, and saw some coolant on the ground, not a whole lot though. Right there in the middle of the motor towards the pass side of the car, read somewhere the pump is in this area.
I am going to be changing the water pump and I heard it was best to also change the timing belt. What else should I change or take a hard look at while I am this far into this job? I have read a lot of the stickys here and other places and I am pretty comfortable with doing it. Are there any pics of this job somewhere?
On what I think is the same issue, my power steering pump loses a lot of fluid when it overheats, is it possible for the ps fluid to evaporate when its too hot, I can't find any leaks here? It doesn't give me any issue until I have an overheating issue.
On another note, I am also having an issue with my suspension I think. While driving down the road I can here a noise that sounds like an intermittent scraping somewhere on the pass side I think. I have looked at the back side of the tire and its not rubbing or being gouged in any way, but something is rubbing.
I hope all the info is here.
2002 PT Cruiser 198163 miles
Old 01 Sep 2014, 12:17 pm
Default Re: Overheating issue
If you saw coolant on the ground, it means that there's now air in the coolant system that replaced that coolant. Any air in the system lowers the boiling point of the coolant and that could/probably is why your overheating. Find that leak and maybe cure that problem.
In out HOW TO thread in the Tech & Performance section there's at least 5 postings on the timing belt change. Some with pictures that take you through the whole process. Good idea to change the timing belt tensioner along with the belt and water pump.
HOW TO's
Old 01 Sep 2014, 12:24 pm
The timing belt tensioner, thats what I thought, what about the hoses you think, I have no idea if the have ever been changed, 198k miles, maybe a good idea, at least the one that hooks to the water pump.
Old 01 Sep 2014, 12:36 pm
Because of the overheating you need to examine the overflow tubing from the rad fill tube to the over flow tank. Check for holes- cracks
Recheck to make sure the (combination low -high motor)low speed fan comes on to cool the radiator
Then turn the AC on Full and the high speed fan to cool the AC condensor should be running with the AC compressor.
A bad radiator cap or and thermostat can cause over heating too.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 01 Sep 2014, 12:55 pm
...and, if you have no idea of when everything was changed, it might be a good idea to start from scratch and change both the upper and lower radiator hoses plus the serpentine and alternator belt. That way you'll know when everything was changed and go from there. The belts have to come off anyway to get to the timing belt/water pump.
Old 01 Sep 2014, 01:00 pm
I have checked what I could of that hose, don't look bad for what I can see, but the overflow tank doesn't seem to move up or down, no change at all.
Recheck to make sure the (combination low -high motor)low speed fan comes on to cool the radiator.
What tool do I use to check this with?
I can't turn on the AC, the plug for the AC pump is broke on the pump side of the connector, bummer, but I can try to play with the plug, wiggle it a little might give me enough connection to run the fan.
I am aware of this, but considering where the coolant drip is, I know the water pump or hose connected to it is leaking. It takes a couple of days of driving before it starts to overheat. And I always bleed the coolant system, but I can't loosen the bleed screw so I do it through the cap.
Old 01 Sep 2014, 01:03 pm
I have already changed the other 2 belts, see original post, the upper hose I can get to from the front, but isn't the lower running to the pump or the block somewhere?
Old 01 Sep 2014, 01:19 pm
Sure, the lower hose (2) is running to the block but if it's never been changed (or you don't know how old it is) then better safe then sorry.
Old 01 Sep 2014, 01:22 pm
I agree Crewzin, but when purchasing the timing belt tensioner, do i need the bracket or just the round piece like this one: http://www.partstrain.com/store/deta...2-97aef35a9871
Or this: http://www.mypartsgarage.com/goodyea...QCkaArbm8P8HAQ
Old 01 Sep 2014, 01:43 pm
Most of us went with RockAuto Parts Catalog to purchase the timing belt KIT which came with everything you need at a good price including the tensioner with the bracket. In 2003-4, Chrysler updated the type of tensioner that was used to a new design.
Overheating issue ted400 General Turbo Discussions 5 10 Oct 2013 12:10 pm
Overheating issue airnut22 Tech & Performance Forum 7 09 Jul 2013 07:19 am
Overheating Issue queen769 Tech & Performance Forum 4 22 Sep 2012 01:16 pm
Overheating Issue Spekstacular Tech & Performance Forum 5 05 Sep 2011 08:41 pm
Overheating issue... derek02PT Tech & Performance Forum 6 22 Jul 2011 12:45 am
