Charging System
Old 02 Sep 2014, 07:26 am
Default Charging System
Hi,
I am still struggling to understand the charging system on the PT Cruiser 2.2 CRD. I am in United Kingdom.
Before the car was not charging, so automatically thought alternator problem,
so replaced it with a reconditioned one still not charging.
Now from what I read on this forum the regulator is not a separate part ie
Not built in to the back of the alternator and the engine ECU controls or
regulates the voltage by a circuit.
Now I have today took the alternator off, to have it checked two companies could not test it, saying it has no regulator. the third company said yes it has
regulator and tested it and said the ignition side of it is faulty.
My question is how can I verify if this alternator has a regulator built in, and the guy also said that it has a regular but its controled via an asd relay and controlled by the circuit in ECU.
Both of these cannot be right it is either one or the other, please any help would be most appreciated. Once I understand the system, I hopefully can sort this matter out.
Thanks
Kevin
Old 02 Sep 2014, 08:11 am
Default Re: Charging System
Can you find a Chilton's, Haynes, or similar repair guide that covers the 2.2 CRD?
We don't get the diesel here.
Old 02 Sep 2014, 09:18 am
The lady guy should be closer to right. If the ads is in the circuit as the alt. then he is correct if set up as the 2.4s.
Old 02 Sep 2014, 12:33 pm
Don't know about 2.2 but IF its close to being the same as 2.4 there should be a fusable link in the heavy charging wire from the alternator to starter.
Check its continuity fom end to end
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Charging System Help RMoore Tech & Performance Forum 21 27 Aug 2012 09:28 pm
Charging system robmet55 Tech & Performance Forum 4 22 Jun 2012 11:18 pm
Charging system battery voltage DJmart Tech & Performance Forum 19 14 Sep 2011 11:26 pm
Charging system issues Murdered Tech & Performance Forum 1 12 Feb 2011 07:37 pm
Looking for charging system mods oldcoach General PT Cruiser Discussions 0 27 Oct 2007 05:16 am
