Am i ok not fixing the evaporator core?
Old 02 Sep 2014, 08:58 am
Default Am i ok not fixing the evaporator core?
I don't really care about the a/c all that much. Especially now that winter is on its way. Is there any risk of further damage if I don't fix it? I would guess not but not 100% sure.2008 PT
Old 02 Sep 2014, 09:09 am
Default Re: Am i ok not fixing the evaporator core?
You will need to replace the drier wit it. Other than that. Probably not.
Old 02 Sep 2014, 12:39 pm
Maybe its the Condensing fan thats not running and the AC is not cooling or did you have confirmation the evap is leaking.
If you have a leak, the compressor will not run because of low pressure , the down side is the defroster may not work good enough with out the AC.
You will cause no other damage by not repairing, its just like not running the AC and defrost even if it works.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 02 Sep 2014, 01:29 pm
I went for a recharge of the system. 2 days later I noticed the green liquid on the driveway and smell out of the vent. Then service center confirmed it.
Old 02 Sep 2014, 02:41 pm
The evaporator usually just leaks freon and maybe some AC lubrication oil.
I hate to break the news but if it is green, I'd bet that you heater core is leaking if your smelling it out of the vent. Is your antifreeze green?
Your interior windows will steam up if its the heater leaking. OR it could be the water pump, how many miles on the car?
If its coming out of the AC drain tube from the interior of the car you have to by pass it or fix it because it will drain the engine coolant if it continues to leak.
73 Charger SE
01 Sebring flip
Old 02 Sep 2014, 03:35 pm
The green was the dye mix with the freon. The coolant is the Orange stuff. It is leaking from the drain tube underneath.
2002 pt evaporator core jaded General PT Cruiser Discussions 2 18 Jun 2013 01:40 pm
AC low airflow, seems to be evaporator RMThompson General PT Cruiser Discussions 3 27 Mar 2012 06:38 pm
A/C Evaporator question.... edwinacuario General PT Cruiser Discussions 1 11 Apr 2010 02:43 pm
air cond. evaporator ptjoe Tech & Performance Forum 2 16 Aug 2009 08:26 am
A/C evaporator leaking ruzz1 General PT Cruiser Discussions 2 11 Apr 2006 01:43 am
