Replaced Clutch and won't start now
Old 04 Sep 2014, 01:51 pm
Default Replaced Clutch and won't start now
Me and my dad just replaced the Clutch in His Pt, And now for some reason he can't get it to start, He says when he goes to start it it acts like the battery doesn't have enough charge but we've checked the voltage of it and its fine. Anyone have any idea what the problem could be?
Old 04 Sep 2014, 02:12 pm
Default Re: Replaced Clutch and won't start now
The first thing to try is a jump start from a good source. You said you have good voltage but didn't say what it is. If jumping it doesn't start it, take the sit filter off to look ay your bettery terminals fit tightness or any corrosion that would stop the voltage from getting to where it needs to be.
Old 04 Sep 2014, 04:03 pm
You didn't by chance disconnect the wireing harness to the cam sensor and coil? Is the clutch releasing? Loose ground at the engine/transmission mounting top left bolt?
Was it running ok just before you did the clutch?
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 04 Sep 2014, 09:12 pm
Was the pressure plate replaced? Sometimes when the pressure plate is replaced it rubs against the inside of the bell housing if its an aftermarket pressure plate.
Old 04 Sep 2014, 09:34 pm
Isn't there a a sensor/switch that clutch has to be depressed to start - like on Autos it has to be in Park?
replaced clutch & used 5spd tranny now no start 96realwe Tech & Performance Forum 9 09 Sep 2013 06:30 pm
2001 PT won't start after spark plug replaced Eddyb General PT Cruiser Discussions 22 07 Apr 2012 01:49 pm
no start no spark replaced just about everything noluck05 Tech & Performance Forum 6 23 Jun 2011 11:55 am
Just had the clutch in my '09 replaced at 5800 miles NotEnufGarage General PT Cruiser Discussions 0 04 Sep 2010 10:03 am
Replaced Camshaft sensor and car still wont start john1561 Tech & Performance Forum 3 29 Jun 2008 06:49 pm
