suspension problem.
Old 05 Sep 2014, 01:16 pm
Default suspension problem.
2001 PT Cruiser, Limited Edition. 130,000 miles.
I'm having a suspension problem I suspect but I don't no what's wrong with it. When speeding up to get on the freeway for example, at about 40 miles per hour it starts to shake much like an out of balance tire.as I speed up going faster the shaking gets worse. But once I let off the throttle to cruise at a steady speed the shaking goes away. Anytime I guess it above the speed of 40 miles an hour its shakez and the shaking goes away when I let up on the pedal. I have already check the front axle bearings and tie rod ends,so I don't believe any of that is the problem. it's a rather slow vibration like a badlybalance tire so I don't think the vibration is internal such as an engine or transmission problem.
Could it be cv joints on the axle?. How would I check those?do you folks have any other suggestions?
Old 05 Sep 2014, 01:27 pm
Default Re: suspension problem.
If your CV joint boots are torn, that's a clue that CV joints are the probable cause.
Old 05 Sep 2014, 01:38 pm
all the CV joint boots are not torn and they look good. No grease is even seeping out of them.
Old 05 Sep 2014, 03:04 pm
Try to putting front tires on the back back to front could be bent rim
Old 05 Sep 2014, 03:19 pm
cruserdad1976's Avatar
the answere could be
WHAT ARE BAD MOTOR MOUNTS????
Old 05 Sep 2014, 04:35 pm
I just rotated the tires. Rims are good.
Motor mounts look good. I can't say for sure but I would think if it was motor mounts it was also vibrate a lot when I took off if I was stepping on it. Please correct me if im wrong
Old 05 Sep 2014, 07:03 pm
I agree that it could be a motor mount issue. Here's a good video I found what bad motor mounts on a PT Cruiser look like
Old 05 Sep 2014, 10:03 pm
I pulled both half shafts and the drivers side inner cv joint boot was off . The ring that holds the boot secure was loose. It kept most of the dust and dirt out but it allowed all of the grease out as well I'm assuming this is the problem since the bearings fit a little bit loose in there now. I'm going toreplace the half shaft but I can't get thebearing housing that slides into the transmission I can't get that out. Any suggestions
Old 06 Sep 2014, 12:00 am
Danny7627's Avatar
I agree with the motor mount theory. I had a similar problem a couple of years ago at 80,000 miles. I replaced the upper and lower mounts and it rectified the problem of the shake when pushing the pedal.
The middle mount (trans mount) I will replace when I do the timing belt and water pump this year...
Check for wear of the rubber on the interior mounts. Mine were dried and falling apart when I eventually wrenched them off and inspected them.
Tis one of the charms of a PT Cruiser..
2008 Convertible Turbo -lite
2007 Touring N/A Boneyard
Old 06 Sep 2014, 11:12 am
I have looked at the motor mounts on they all look brand new.
OEM Suspension Flowrider General PT Cruiser Discussions 11 22 Aug 2013 12:02 am
rear suspension problem partyd General PT Cruiser Discussions 6 14 Nov 2010 03:38 pm
Suspension problem, ticks and clicks geronimo Wheels, Tires, Suspension 4 28 Jul 2009 04:22 pm
Air Bag suspension TaylorMade Wheels, Tires, Suspension 5 01 Aug 2004 12:50 am
air suspension Jonez3 Tech & Performance Forum 3 03 Jul 2003 05:52 pm
