2001 PT Cruiser limited power steering fluid boiling
  • 1 Post By domsob1974
Old 05 Sep 2014, 01:17 pm
domsob1974's Avatar
Default 2001 PT Cruiser limited power steering fluid boiling
Hi
I did a rebuild on my pt. I got most of the gremlins out but the power steering fluid seems to be boiling and coming out from under the cap and dripping on to the exhaust manifold. what causes this and how do I fix it.
thank you in advance
Old 05 Sep 2014, 01:37 pm
Handy_Cruiser's Avatar
Default Re: 2001 PT Cruiser limited power steering fluid boiling
In most cases, the fluid is not "boiling". Instead, the power steering system may be sucking air. And then the air displaces the fluid. In this situation, it blows out fluid most when you turn the wheels far to one direction and then the other. Check for a loose or cracked line.
Old 05 Sep 2014, 04:31 pm
boonie2's Avatar
Fix it soon or that will be the least of your troubles when the fluid catches fire
2004 Pt Cruiser 2.4 L {non turbo} 113K miles , Electric Blue pearl {PICTURES in my Profile Album}
Full Synthetic Oil 10w30 K&N Filter
Full Synthetic Trans Fluid / filter Change :bolt-away
Old 07 Sep 2014, 05:46 pm
domsob1974's Avatar
Looked at all of the lines and I didn't see any of them cracked, or too close to the exhaust manifold. I guess Chrysler was serious when they put the FILL MAX COLD and FILL MAX HOT markers on the Power Steering reservoir. It was overfilled. Drained some out and it seemed to have fixed my problem
Old 07 Sep 2014, 06:40 pm
That's true of the overflow bottle also - add coolant over the max line and it will pee it out when it heats up.
pt cruiser leaking power steering fluid when sitting idle win717 Tech & Performance Forum 0 28 Jun 2014 06:05 pm
2001 power steering fluid? nitram01 General PT Cruiser Discussions 11 15 Nov 2013 12:40 am
2001 Pt Power Steering Fluid? 01limited94 General PT Cruiser Discussions 2 08 Mar 2013 01:22 am
pt cruiser 2002 limited power steering prob ftruji2 Tech & Performance Forum 3 25 Oct 2012 09:50 pm
pt cruiser 2002 limited power steering prob ftruji2 Tech & Performance Forum 1 24 Oct 2012 11:29 am
