Here are the Torque Specs For the Lower Engine Mount
Old 05 Sep 2014, 11:07 pm
Default Here are the Torque Specs For the Lower Engine Mount
I replaced the lower engine mount today after discovering it was completely torn.
Torque strut mounting bolts: 85 Ft. LBS.
Pencil strut bolts: 43 FT. LBS.
Here's my story:
Yesterday, I pulled my car in my garage to clean a spill with the Hoover carpet cleaner. I decided to check all the fluids since it's one of the few level spots. I took a peek underneath to check for leaks and noticed that the lower engine mount was completely torn. I first noticed it starting to tear around 50,000-60,000 miles. I was going to get the mount from O' Reilly's or Rock Auto but they weren't very specific on whether it was for the wagon, convertible, automatic, or manual transmission so I got it from the dealer. After replacing the mount, I noticed that the hood doesn't vibrate as much and the transmission doesn't engage with a thud when I accelerate from a stop. I'll replace the other 3 mounts when I do the timing belt. The other mounts are probably still good but they're all the same age. These cars are really bad about motor mounts. I think it's because they put all 3 on the same side of the engine instead of 1 on each side. I probably spent just as long looking up the torque specs as I did working on the car so I figured I'd save someone else the time and hassle. I got the torque specs from Mitchell On Demand. I prefer All Data but Mitchell is what they use at work.
2008 PT Cruiser Touring 135,000 miles
Engine mount/ torque struts BigApple Tech & Performance Forum 9 02 Oct 2017 11:22 am
Energy Suspension Bushing - Lower Torque Mount - Is this correct? greeley Wheels, Tires, Suspension 4 25 Sep 2013 09:52 am
How Hard Is It To Replace Lower Motor Mount (Torque Rod)? myjeephatesme Tech & Performance Forum 16 02 Nov 2012 06:50 pm
Lower motor mount bolt specs (missing bolts) joe504 Tech & Performance Forum 2 17 Sep 2011 05:28 pm
What are the left engine mount torque specs? geronimo General PT Cruiser Discussions 2 22 Mar 2010 02:23 pm
