trying to get error code
  • 1 Post By quicksilverdon
Old 09 Sep 2014, 05:44 pm
Unhappy trying to get error code
I have attempted many times to get the error code to appear on my display. I have followed Skylight's instructions for retrieving error codes.
2005 PT Cruiser
the engine light is on and the car stuttered once then lost its thrust I dared not push over 25 and luckily made it back home that was only a few blocks away.
Any suggestions something I am not aware of? like clicking my heels together three times or rubbing the dashboard and make a wish?
or could it be something more sinister... and the car dislikes me?
I am at my wits end, and when I walk into a car repair place I can hear the mechanic calling on the phone making vacation plans as my bank account goes into the red.
thank you for any decent advice help that can be offered.
Old 09 Sep 2014, 06:07 pm
Default Re: trying to get error code
As an Auto Diagnostic Technician I have been posting for a couple years now that the Key access method for viewing DTCs does not always work and is not reliable.
You really should get the OBDII diagnostic port scanned with a proper Diagnostic Scanning Tool to retrieve the DTCs.
May I also suggest that you start over as a new member and take a little time to do an introduction? Perhaps fill out your profile? You may get more help for members?
PT problems read this FIRST
Old 09 Sep 2014, 06:12 pm
Well, you can try to make sure the actual mileage is showing on the display before you do the "key dance". Sometimes the codes don't display when the trip odometer is showing.
If it still doesn't work, as Nitro suggested, buy yourself a code reader to find out what is up before getting taken to the cleaners at your local garage or at the stealership.
Old 09 Sep 2014, 06:35 pm
LionPT's Avatar
To do the key dance, turn everything in the car off, no stereo, wipers, lights, etc., just to keep the system load down. Turn your key to the accessory position, that is two clicks prior to the start. So, you have Off, Acc, On, and Start (which is the spring-loaded position). Turn to Acc, wait a few seconds, then On, Acc, On, Acc, and On... leave it in the On position (NOT THE MOTOR START POSITION!), you should see a series of dashes ------ at your Odometer, while the PT runs the internal diagnostics testing. Takes maybe 10 to 15 seconds or so and then it will return the DTC's (diagnostic trouble codes).
Old 09 Sep 2014, 06:50 pm
If Lion's instructions don't work for you, drive to an AdvanceAuto or other parts store - they'll plug in a reader and read codes for free...
NitroPT likes this.
Old 09 Sep 2014, 08:31 pm
There might be a good chance the cam sensor quit working and when the cam sensor quits working the PT Cruisers goes into a limp mode but first thing that needs to be done is to determine if its electrical or fuel related problem. Engine trouble codes can help determine the problem.
Thanks for error code help mycar Tech & Performance Forum 3 11 Aug 2012 07:25 am
What does the error code PO 138 really mean? TheFox General Turbo Discussions 8 15 Jul 2012 10:10 pm
Error Code 320 okla2001pt Tech & Performance Forum 1 17 May 2010 12:42 pm
error code... superpug666 Tech & Performance Forum 16 13 Oct 2009 07:33 pm
S1 error code??? mtnbktrek Stage Turbo Kits 2 24 Feb 2009 01:42 pm
