alternator problems
Old 09 Sep 2014, 09:23 pm
Default alternator problems
I have had my pt about eight months it is an 01 2.4 this past fri my battery light came on that evening it wouldn't start I got a jump from a friend I was able to drive about six miles and had to be jumped again to make it home Saturday morning I went to my local junkyard got an alternator spent all day changing it out when I started the car it started screaming like the bearings were bad it also wasn't charging they were closed til today I took it back they gave me another one I had it tested at advance auto parts they said it was good ive put it on today and still not charging battery light is on I removed my hot cable from the battery and it died instantly I really hate to buy a new alternator if the problem could be somewhere else has anyone else experienced this problem or have any ideas
Old 13 Sep 2014, 10:44 am
Default Re: alternator problems
It's probably a wiring problem and not an alternator problem. My advice would be to find a wiring diagram (page 12-19 if you have a Haynes manual). I would start by checking fuse #13. If that's good, check the auto shut down relay. If that's also fine and dandy, I'd check the wiring going to and from the alternator.
2008 PT Cruiser Touring 135,000 miles
Old 13 Sep 2014, 10:45 am
Wiring diagram for 2001 and 2002
Replaced PCM Old Problems Fixed - New Problems Arise!! adstatus Tech & Performance Forum 4 12 Oct 2013 07:49 am
H/O Alternator jonnbr Sound and Security Forum 0 18 Nov 2009 02:08 am
alternator hillbilly678 Tech & Performance Forum 4 05 Nov 2009 02:51 pm
alternator? DARK270 General Turbo Discussions 13 07 Mar 2005 02:27 am
Alternator Mark Tech & Performance Forum 0 13 Feb 2002 05:46 pm
