New member - oil leak issue
Old 11 Sep 2014, 03:04 pm
Default New member - oil leak issue
2003 Base PT Cruiser with about 128K miles on it. The oil breather hose appears to have split and may be leaking oil in to the engine area. Would this be possible? Noticed the smoke and smell of oil yesterday. Popped the hood and the hose was off at the engine mount side. Forced it back on to drive home and did not see or smell smoke. Came to work this morning and could smell the oil smoke. When I turned of the car, there was a lot of smoke when I opened the hood. Hose was detached again from the engine side. Looks like there may be some oil on the top of the engine near the power steering reservoir...
Would this be OK to drive to the repair shop? About 10 minutes away or so if I can get the hose back on?
Any and all response would be helpful! Thank you!!
Old 11 Sep 2014, 03:10 pm
cruserdad1976's Avatar
Default Re: New member - oil leak issue
well id check to make sure you are not really low on oil but it thats ok id drive it a little oil makes a lot of smoke
Old 11 Sep 2014, 03:15 pm
Thank you for the reply. Will definitely check the oil level before attempting. Would that oil breather hose be responsible for the leaking oil do you think or am I needing to look further?
Old 11 Sep 2014, 03:22 pm
are you sure it isn't power steering fluid leaking out of the reservoir? just asking because MINE leaked onto the top of the valve cover due to a leaky power steering fluid cap. i though it was oil for the longest time... the P/S fluid is yellowishly clear and looks like oil.
Old 11 Sep 2014, 03:25 pm
OK, will check that as well. Would it smoke as bad as oil?
Old 11 Sep 2014, 04:26 pm
OH YES its a NASTY smell too
Old 11 Sep 2014, 04:45 pm
Look along the edge of the valve cover for leaks, too.
If oil level is okay, (above the low mark) car is fine to drive.
Old 13 Sep 2014, 10:07 am
You're supposed to use ATF+4 for the power steering.
2008 PT Cruiser Touring 135,000 miles
Old 13 Sep 2014, 10:10 am
Are you sure it's the crankcase vent hoses? The breather hoses are near the air filter housing on the driver side of the engine. Definitely check the fluid levels and take it to a shop.
Old 29 Sep 2014, 09:43 am
Following up to my original post. Valve cover gasket needed to be replaced. Paid a hefty sum to have repaired and on the way to work this morning, noticed the oil smell as well as some smoke again when I turned off the engine. Opened the hood and did not notice any new oil on top of the motor so I am just wondering if this is burning off what was already on the engine? Would it be best to take it back to the repair shop and have them take another look?
P0455 Major Evap Leak Major issue h_wingman Tech & Performance Forum 16 27 May 2018 12:03 pm
New member carnut52 Welcome New PT Cruiser Members 7 23 Dec 2013 10:33 pm
New member Mts7072 Welcome New PT Cruiser Members 5 18 Oct 2013 06:58 am
Well - Not a New Member SilverSport Welcome New PT Cruiser Members 4 28 May 2013 12:05 pm
Oil Leak, Vacuum leak Ikster Tech & Performance Forum 1 02 Jan 2013 09:53 pm
