07 pt not starting
Old 12 Sep 2014, 02:59 pm
Red face 07 pt not starting
I just changed the transmission in my 07 pt now it will not start.I have installed a new battery,starter and neg battery cable and cleaned the grounds.The solenoid will pop out but will not spin.Getting tired of changing parts,Thanks for the help john
Old 13 Sep 2014, 10:29 am
Default Re: 07 pt not starting
How many volts are you getting at the starter when you crank it?
2008 PT Cruiser Touring 135,000 miles
Old 13 Sep 2014, 12:01 pm
Is the transmission manual or automatic?
Is the transmission the same as the original transmission?
Did it have any starting problems before you replaced the transmission?
Why was the starter replaced?
Did you check to make sure the new starter is exactly the same as the old starter? Same brand?
Did you replace the starter at the same time you replaced the transmission and it would not engage?
Is the starter gear stuck on the flywheel?
Has the new starter been removed and tested?
Not starting sunny8088 General PT Cruiser Discussions 12 10 Apr 2014 12:43 pm
02 Not Starting jpcruz Tech & Performance Forum 7 29 May 2012 07:59 pm
Looking for starting help bluesanity General PT Cruiser Discussions 3 20 Mar 2010 12:16 pm
'03 Not starting GunnerIke Tech & Performance Forum 6 29 Oct 2009 09:55 am
Just Starting air4cefamily General PT Cruiser Discussions 3 29 Mar 2008 08:41 pm
