2005 pt cruiser
Old 12 Sep 2014, 06:32 pm
Default 2005 pt cruiser
Does any one know the part # of the plastic support that holds up the fuel supply line to the fuel rail?
Old 12 Sep 2014, 06:39 pm
Default Re: 2005 pt cruiser
I don't, but they didn't have that piece for the earlier cruisers when the fuel line caught fire and caused the recall. But, I'
m sure your not going to be able to obtain that piece of plastic anywhere but a dealer (if they still make them) so why not just stop by a dealer and ask them if they can still order you one?
Old 12 Sep 2014, 06:53 pm
the reason I asked I just called the dealer and they couldnt even find a listing for one
Old 12 Sep 2014, 07:14 pm
Somebody had a good picture of one but I can't find it. On the 2002 recall, we all brought our cruisers into the dealer and they actually used a Tie-Wrap to pull the fuel line away from the A/C lines so they wouldn't rub and cause a leak and fire. I believe in 2003/4 that they made the piece your looking for that bolted to the engine, was about 3/4 inches high and clipped onto the fuel line guiding it away from the A/C line.
I guess until you track it down, you can do it Chrysler's way and use a Tie-wrap to keep the fuel line far enough away from the A/C not to cause it to rub.
Old 12 Sep 2014, 07:35 pm
the one I'm looking for mounted to the strut tower and is about 10" high
Old 12 Sep 2014, 07:43 pm
Maybe they made more than one or somebody before you made their own.
Old 12 Sep 2014, 08:11 pm
Part number CL (or maybe OL) 0001685 >PA66< 2
This bracket can be seen by timing belt cover. Look carefully and you can see the grayish color of epoxy fixing it to the bracket.
The piece as pictured above snaps into a hole.
The mechanic who changed my timing belt applied the epoxy (probably broke the bracket).
2005 Cruiser sancapwork Tech & Performance Forum 10 21 Jul 2014 12:48 pm
2005 PT Cruiser TCM adstatus Tech & Performance Forum 2 16 Aug 2013 12:06 pm
I need help please!! 2005 PT CRUISER Purr0066 Welcome New PT Cruiser Members 1 23 Jun 2012 06:49 pm
2005 PT Cruiser FS TurboDucky Classifieds: For Sale/Trade 0 10 Apr 2012 04:16 pm
2005 PT Cruiser Blakduke Classifieds: Want To Buy 4 20 Aug 2008 02:58 pm
